I am trying to program a bootloader-application combination at MPC5643L using CodeWarrior 10.5.
Bootloader and application communicate by a shared structure therefore the pointer to this structure must be located to a fixed address.
The access to the structure members via this pointer is located in various other files which are being shared with other projects so it's difficult to change the declaration of the variable.
So here's my question:
Is it possible to locate a variable (in RAM) on a defined address without using the __declspec keyword ?
I tried this:
volatile tTableStruct TheTableStruct; #pragma push #pragma section RW ".ptrTableStruct" volatile tTableStruct *TableStruct = &TheTableStruct; #pragma pop
It compiles but the section ".ptrTableStruct" is empty and the pointer "TableStruct" is located somewhere in RAM.
Then I tried this:
volatile tTableStruct TheTableStruct; #pragma push #pragma section data_type ".ptrTableStruct" volatile tTableStruct *TableStruct = &TheTableStruct; #pragma pop
This leads to an linker error:
sections used for data must have an uninitialized data section in line #1
Thank you,
Markus
已解决! 转到解答。
Hello markusa,
The pragma section requires also uninitialized section parameter to add for the data sections.
If you have a small data threshold set to a default value which is 8 you should add also "sdata_type" parameter in order to place the pointer into your custom section.
Could you try to adjust the pragma section:
#pragma push
#pragma section data_type sdata_type ".ptrTableStruct" ".ptrTableStruct"
#pragma pop
Hope it helps.
Stan
On older versions of codewarrior it works like:
extern volatile tTableStruct TableStruct @0xAAAAAAAA;
// where 0xAAAAAAAA is the addres you want your struct be placed.
volatile tTableStruct TableStruct;
Hello markusa,
#pragma push
#pragma pop
Hope it helps.
Stan
Hello Stanislav,
thank you - this solves the error.
Maybe you can help me with the 2nd issue too ...
The variable "TableStruct" is used in several (shared) files.
To access the variable I use the following code in each C-source file:
extern volatile tTableStruct* TableStruct;
But to be able to use these files with CW and other compilers I have to change it to:
#if defined(__COMPILER_CODEWARRIOR_ECLIPSE__)
#pragma push
#pragma section sdata_type ".ptrTableStruct" ".ptrTableStruct"
extern volatile tTableStruct *TableStruct;
#pragma pop
#else
#endif
Do you think there is a better solution ?
Thank you for your time,
Markus
Hi Markus,
there is an alternative way which does not require #pragma push/pop (so you can use a macro):
the "test.h" header file:
#pragma section RW ".ptrTableStruct" ".ptrTableStrct" // defines a custom section to be used with __declspec(section ...)
#define CW_DEF __declspec(section ".ptrTableStruct") // Create custom __declspec() macro
#if __CWCC__ // internal compiler macro to identify CodeWarrior Compiler
CW_DEF extern volatile tTableStruct *TableStruct;
#else
extern volatile char* TableStruct;
#endif
a source file where table is defined:
#include "test.h"
CW_DEF volatile tTableStruct *TableStruct;
Hope it helps.
Stan
Dear markusa,
Thank you for your post, however please consider moving it to the right community place (e.g. CodeWarrior Development Tools ) for better visibility.
For details please see general advice https://community.freescale.com/docs/DOC-99909
Thank you for using Freescale Community.
Wlodek_D.
