MPC8640D Failed to reset the target (core did not halt)
535 次查看
nagajyothi
Hi  all,
we are working on a project CPCI Based SBC Board using MPC8640D processor.
We are trying to get simple JTAG connection to the processor mpc8640d. We
are using code warrior USB tab s/n 0839 0023.
  In code warrior, when I try to reset the MPC8640D core (via reset target
on launch), it gives the following message:
"CCSProtocolPlugin: Failed to reset the target (MPC8640d Core: Core did not
halt)."
we are monitoring the jtag signals also , HREST and SRESET signals are not
coming..by default these signals are in high state(+3.3v).
Can you give me some guidance in interpreting this error ?
Thanks and Regards,
Jyothi
367 次查看
trytohelp
Duplicated to the SR# 1-3927022918.
Answer provided via SR#
This error means the debugger can not take control over the core. Usually, this happens if core is not responsible to debugger commands - did not come from reset, or entered checkstop state due to some error condition.
If the core does not core from reset, than please ckeck basic things - power on configuration, clocking, power supplies, etc.
Pascal
Freescale Technical Support
