JTAG 调试完后, 重新上电后不是之前调试的程序了。怎么解决 // JTAG debug finished, re-power not before commissioning program. How to solve
847 次查看
nihao
如何解决 JTAG 调试后, 重新上电程序不是之调试的程序,新人多多指教,谢谢。
How to solve the JTAG debugging, re-power program is not the program being debugged, new exhibitions, thank you.
Message was edited by: Monica Arvizu Translated by www.translate.google.com
547 次查看
ZhangJennie
I wonder you should not select the build target as XXX_INTERNAL_FLASH. thus the code wasn't  downloaded to FLASH when debugging.
please make sure you have the build target as XXX_INTERNAL_FLASH selected.
please mark the correct answer if this solves your problem. thanks!
