CodeWarrior ARMv8 - not setting HWA_CGA_M2_CLK_SEL RCW bits
770 次查看
Davisg
When using CodeWarrior ARMv8 to generate a binary RCW to use for NOR FLASH boot of an LS1043A processor, the QorIQ configuration tool is not setting the HWA_CGA_M2_CLK_SEL bits (509-511). These bits are always set to 000 no matter which option is selected in QorIQ configuration.
I know that u-boot will generate the RCW/PBL with checksum from cfg files, and include the generated RCW/PBL in the binary for SD card and NAND boot but u-boot does not have facilities to do the same for a NOR image. How can I generate an RCW/PBL with HWA_CGA_M2_CLK_SEL set correctly and checksum generated outside of the CodeWarrior QorIQ configuration tool? Or is there a fix to the QorIQ configuration tool in CoeWarrior ARMv8?
标记 (1)
655 次查看
addiyi
You need to update QCVS to latest version which is 4.7.
655 次查看
addiyi
What QCVS version you are using?
Adrian
655 次查看
Davisg
CodeWarrior Development Studio for QorIQ LS series - ARM V8 ISA
(c) Freescale Semiconductor, Inc. 2014. All rights reserved.
Learn more about CodeWarrior at
http://www.freescale.com/codewarrior
Version: 11.2.0
Build Id: 160115
656 次查看
addiyi
