Code warrior enquiry
465 次查看
debduttabanerje
We intend to debug and validate boards based on T-series QorIQ processors.
Please confirm that following parts will be sufficient:
1. CWH-CTP-BASE-HE (basic unit)
with
2. CWH-CTP-COP-YE (removable probe tip)
We want to use the QCVS (ddr validation suite). Do we need to purchase license for that separately? Or it is bundled in with the above hardware.
Please also attach the codewarrior software installation package
440 次查看
yipingwang
1. Your purchased CodeWarrior TAP and the probe tip are correct.
2. You need to purchase Specialist Level Suite CodeWarrior license from https://www.nxp.com/design/design-center/software/development-software/codewarrior-development-tools...
3. I uploaded CodeWarrior and QCVS(DDR) tool in the following link.
https://support.nxp.com/s/case/5002p00002zooySAAQ/community-code-warrior-enquiry?language=en_US
Please install CodeWarrior for PA 10.5.1 first, then open CodeWarrior IDE and install QCVS for PA 4.5 from Help->Install New Software->Add->Archive.
294 次查看
debduttabanerje
NXP team,
Is it possible to run codewarrior on linux along with qcvs suite?
434 次查看
debduttabanerje
Thank you so much.
441 次查看
yipingwang
