Hello 秀峰
User can use hiwave in CodeWarrior v5.1 to dump memory from MCU. To do it, please input SAVE command in debugger command Window to save a specified block of memory to a specified file in Freescale S-record format. Eg.
in>SAVE 0x1000..0x2000 DUMP.S19 ;
This way can read binary opcode from flash to s19 file. Appends the memory range 0x1000..0x2000 to the DUMP.S19 file.
With S19 file, you can program the device by Hiwave.exe in CodeWarrior.
P&E supplies a standalone tool which can copy and program data using USBDM:
Hope this helps!
Best Regards
Fiona Kuang
TIC - Technical Information Center
