Me again!
Now with a doubt about a small portion of code... I use cppcheck to find error that compiler can not detect. Well, it acuse this error, but I can't still figrue it out.
Here's the code:
byte* const Tabla_CamposDir[]={ DIR_hora, DIR_cta_cte, DIR_calle, DIR_numero, DIR_ubicacion, DIR_pasajero, DIR_demora, DIR_comentario, DIR_zona, DIR_base, DIR_calle1, NULL, // NOTHING DIR_tarjeta, DIR_pactado, DIR_calle2, DIR_opcional1, DIR_opcional2, DIR_opcional3}; void DIRECCION_resetCampos (void){ word i, j; byte* ptr; for (i=0; i<(sizeof(Tabla_CamposDir)/2); i++){ ptr = Tabla_CamposDir[i]; // Erase 6 bytes of each buffer (minimum length) if (ptr != NULL){ for (j=0; j<6; j++){ *(ptr + j) = 0; } } }
What's inside Tabla_CamposDir are all arrays of at least 7bytes each, I mean:
byte DIR_hora[7];byte DIR_cta_cte[10];
The cppcheck says: Buffer access out-of-bounds: Tabla_CamposDir
at ptr = Tabla_CamposDir[i];
If that's rigth.... How can I solve it? Maybe I'm blind, but I can't figure it out!!
Thanks to you all!!!
已解决! 转到解答。
Hi Sebastian,
sizeof(Tabla_CamposDir)/2 is only the number of elements in the array if the sizeof a byte* is 2. I am not familar with cppchecker, but you would need to check what size it assumes a pointer to a byte const is. If cppcheck thought sizeof(byte *) was 4, then it would indeed flag a access out-of-bounds.
A better way for calculating the number of elements would be : sizeof(Tabla_CamposDir)/sizeof(Table_CamposDir[0])
David
Hi Sebastian,
David
Hi David!
Well, you're the winner!!! LOL!
Thanks for taking a look at it.
You're rigth, I didn't notice that the size of pointer to byte could be different. With the modification you suggest no errors are thrown
Thanks a lot!
