Hello
Not sure which processor you are targeting (HC08, Coldfire, ...) and which version you are using.
Answer to that question might depends on the target CPU, version number and product you have ordered.
Here is the answer for the latest CodeWarrior products.
Basically if you want to share a license between two computers you have following solutions:
1- Use one computer as a license server and have the two computer consuming the license there. If you want to go this way you have to order a floating license for 1 user. Then you have to install FLEXlm software on the license server and start a service to make th license available. This is explained in the user manual.
2- Get the license linked to a USB dongle. Just place the dongle in a USB port on on machine to be able to use the tool on that machine. In that case you have to order a dongle license.
Be careful, solution 2 only works with recent version of the tools.
I hope this helps.
CrasyCat
Hello
Did you order a floating license or a single user one?
Did you order a special edition? ... We do not deliver floating licenses for special edition.
If you ordered a floating license and after you have installed FLEXlm software, take a look at the file C:\FLEXlm\htmlman\enduser.pdf.Section 6.3.2. Configuring the License Manager as a Windows Service provides info on how to do that.
CrasyCat
