Exact image of the flash
joe
Is their a way to obtain the exact image of the datas stored on flash via the Metro Works code fire. I do not want a binary file of the s19 file. I would like to have the exact imge. My last solution is to extract data directly from the flash.
toucan
Pls go to Debug->ColdFire->Load/Save Memory to grab the exact binary image in the Flash.  Before any attempt to do that, you have to connect to your target by Debug->Connect.
