The -[no]dead[strip] option is used to enable/disable the dead-stripping of unused code.
By default the dead-stripping is enable. to reduce the size of code.
If you disable it and linked a library to your application, all libraries functions will be included in your application.
This is the case on your side as you're using the MSL C 56800E.lib library.
You disable the dead stripping feature and got some linker errors.
The problem is that the library refers to some functions which one were removed of your application with the dead stripping option.
You have 2 solutions:
- implement the functions,
- use the dead stipping option.
Hope this will help you.
Pascal
