Internal Linker Error: File: ELF_gen.c ???
1,568 次查看
Karl_H
CW version = 5.9.0
Processor = PowerPC 8270
What is the meaning of
Internal Linker Error: File: 'ELF_gen.c' line 978
There is no such file in my code or the code delivered with CodeWarrior. And searching the help files on this turns up nothing.
I am trying to configure a bare-bones application. I used the same procedure for this application as for another one I recently created that builds without this error.
KH
624 次查看
J2MEJediMaster
Specialist I
Internal errors are usually a bad sign. Please file a service request on this. Be prepared to supply a project and source that does not give away your IP but can reproduce the problem. Click here to submit a service request.
624 次查看
Karl_H
It turns out that I had conflicting addresses for the entry point in the configuration. When I fixed that, the problem went away.
KH
624 次查看
CompilerGuru
Would still be good to get it fixed for other users so the error could be improved from
"internal linker error" to "conflicting entry point address" :smileyhappy:
So please file a report...
