Hello, I am looking all over the web to try and find the codewarrior program i use in my school for c++. I see that this is the only website and when i go to the download sections, there are so many to choose from! i need to find out which one is the right one to pick & were i can get the codewarrior IDE for wndows 7, 64 bit computer! any help would be great!
cout<<"help with codewarrior"<<endl;
Hi Kelman,
Here is a tool that may help you get the best option for you. CodeWarrior Selector Tool
What is the part number of the MCU or Processor that you are using?
Special Edition: CodeWarrior for Microcontrollers 10.6 (Eclipse, Online) may suit for you.
It depends upon what you are trying to do here. If your intent is to write and run C++ programs on your desktop/laptop, CodeWarrior does not do that. (It used to be able to generate Windows apps, but that capability has been discontinued years ago.)
If you are going to be writing programs for embedded processors, you need to tell us which processor you are targeting before we can give you an answer. As you have noticed, there are many different versions of CodeWarrior, each which generates code for a specific processor.
---Tom
