Debugger error
Debugger error
4,534 次查看
ni
We are programing Freescale 56F8357 DSP in Metrowerks CodeWarrior IDE.
Our problem, derives from 2 Code Warrior IDE versions that we are using. Until now, we are working with two licenses:
- One fix license: CodeWarrior 56800/E Hybrid Controllers version 6.1.2
- Another floating license: CodeWarrior 56800/E Hybrid Controllers version 7.0
Up to now, we have debugged a program "bootloader.c" in version 6.1.2 without problems. But now, we have tried to debug using version 7.0 and we don´t arrive. Each time that we try to debug (we have Compiled and "Make" without problems), it appears a message saying "CCSProtocolPluging. CCS: Invalid Parameter".
We have changed our parallel port in CCS console (we have put address 0x0378) and message from CodeWarrior debugging has changed: "CCSProtocolPlugin: Unknown protocol error".
But after accepting this message, it appears again the message: "CCSProtocolPluging. CCS: Invalid Parameter".
- What could we do? What could be the solution for this problem?
We will really thank you your help with this item.
标记 (1)
4 回复数
711 次查看
marc_paquette
Contributor V
The cause of the problem might be conflicts with your parallel port. Is another application or service using it?
Alternately, this thread might help:
Let me know if the problem persists.
Marc.
711 次查看
kanu__
hi,
I am also facing the same error in Code warrior 3.0 for MSC 8122 ADS proeject download.
Here the link you provided is not working.
http://forums.freescale.com/freescale/board/message?board.id=CWCOMM&message.id=518
__Kanu
711 次查看
J2MEJediMaster
Specialist I
Try this link instead: https://community.freescale.com/message/11176#11176. I hope this helps.
---Tom
711 次查看
kanu__
No. I am getting the same error again when i trying to download to 8122 board in CW 3.0.
The interesting thing is that , i can download into my 8101 and 8144 board using the same usb tap and code warrior versions in the same PC  now also with out any problem.
Earlier(2 weeks earlier) i had tested(had downloaded) the 8122 board with the same settings but i don't know what happened(no change in project) now.
Please help me out
__Kanu
