how to use "goto" with different file.
3,313件の閲覧回数
eexpress
i had a label 'SYS_RST'; within main.c.
now want using 'goto SYS_RST' within rtc.c.
how can i define the SYS_RST in my rtc.c file. such as:
extern const *(void *) & SYS_RST;
plz help me.
for this is some special condition i must use this 'goto'. and i had search in CW's complie manual, but no answer.
if some advice, also can directlly send a message to exp.exp,gmail,com.
thanks
3 返答(返信)
928件の閲覧回数
CompilerGuru
You cannot use the ANSI-C goto to jump across functions.
Does the ANSI-C longjmp work for your problem? Otherwise real assembly?
Maybe we can help if you let us know the problem you try to solve so we see why a normal function call does not work for your case.
928件の閲覧回数
eexpress
the reason is with some special conditions, my chips need partly reset. that' say just need jump to the location after CGM_Ini(). and all other steps such as initilize datas need be operated.
so i using a label called SYS_RST after CGM_Ini(). and want get the absolute address of SYS_RST. so i can directlly jump to here.
of course i can set a flag when meet the special conditions in other c file, and within my main() i judge this flag and jump to SYS_RST.
but really i want know if i can using a assembler way to do this. so if i can find how to define the label as a absolute address. i can using "asm jmp xxxxx".
thanks
928件の閲覧回数
Lundin
Senior Contributor IV
longjmp() would probably work, yes.
But since that is sort of quick & dirty, perhaps you could concider a different design? Something like this perhaps:
int main()
init_out_of_reset();
for( ;; )
init_some_more();
while(everything == OK)
if(weird_error)
everything = NOT_OK;
