Windows version of the HCS08QG8 bootloader
2,381件の閲覧回数
FC
Can a windows version of the HCS08QG8 bootloader be made?  The dos prompt becomes hard to work with.
How difficult will it be to make a simple GUI for the bootloader program?
3 返答(返信)
443件の閲覧回数
Curt
Hi FC:
It should be pretty easy to write a windows GUI "wrapper" for the DOS program using
something like Delphi or Visual C if you have access to the bootloader's command line interface.  But writing a native windows bootloader might be really hard (depending on windows version) if it needs to use interrupts.   Since Win98, it has become harder and harder to interface directly with the hardware on your PC, and especailly the interrupt ports.
443件の閲覧回数
ok2ucx
Lucky you,
the GUI already exists, it's being tested and will become a part of the next AN2295SW release. Unfortunately I don't know when this occurs.
Attached you may try this alpha version and give us the feedback on how/if it works for you.
Pavel ok2ucx
AN2295 developper
Alban Edit: FSL s/w need a license acceptance. Working on packaging it and reposting.
Message Edited by Alban on 2007-05-25 02:45 PM
443件の閲覧回数
Alban
Senior Contributor II
Here is a packed version with license.
Cheers,
Alban.
AN2295-Bootloader-Control-alpha-1.exe
Message Edited by t.dowe on 2009-10-20 01:30 PM
