I facing a strange issue of continuous reset on my S9S08SG8 board. The SG8 seems to be resetting continously as the scope connected to reset pin shows a square wave of about 25Khz. To isolate the problem I connected only VDD and GND with a 10K pull up to RST. I can still see a 25Khz squre wave on RST.
If I pull up the BKGD/MS pin while booting, RST shows steady 5 V. P&E is unable to program the IC.
Am I missing something ?
Pramod
解決済! 解決策の投稿を見る。
Dear Pramad,
The symptoms you describe are usually caused by a COP timeout or Illegal instruction reset. Judging by the frequency I suspect the latter. Holding BKGD low during power-on causes the device to enter BDM mode disabling the COP and instruction execution. This can occur if the chip is blank or programmed incorrectly. Once programmed it usually isn't a problem.
I would expect that the P&E BDM would be able to to do the same thing (i.e. hold BKGD low) while prompting you to cycle the target power.
Does the P&E BDM work with other chips?
If so try the following sequence:
Hold BKGD low while powering on (use a 100R resistor if it works to avoid damaging the BDM).
Connect the P&E BDM.
Release the BKGD pin.
See if the BDM can connect now.
bye
If I pull down the BKGD/MS pin while booting, RST shows steady 5 V. P&E is unable to program the IC.
instead of
Pramod
Dear Pramad,
bye
Thanks PGO !!!
Holding the BKGD low manually seems to solve the problem. I expected the P&E to take care of this but for some reason it doesnt.
