Page boundaries for flash block erase - question
725件の閲覧回数
russellsher
I am using an MC9S08QE128. Looking at the memory map:
There is an 8064 byte flash block from 0x2080 to 0x3FFF.
If I want to erase a 512 byte block of flash, (I am using doonstack), must the block start at a page boundary such as 0x2100? The RAM space above this block in the memory map is 0x1880 to 0x207F. Can I erase from 0x2080 since this is not the start of a boundary or would I have to erase from 0x2000 ? (which may cause problems, since the ram extends to 0x207F)
thanks
Russell
582件の閲覧回数
kef
Specialist I
You can erase sector at 0x2080. This will erase whole 512bytes sector. You'll get erased nonbanked addresses 0x2080..0x21FF, also banked addresses PPAGE=0:0xA000 to PPAGE=0:0xA1FF.
2 返答(返信)
583件の閲覧回数
kef
Specialist I
582件の閲覧回数
admin
Specialist II
many thanks for the reply
