MPC5606B error
MPC5606B error
1,117件の閲覧回数
khaleadpark
Hi.  I have TRK-MPC 5606B board.
I have a problem.
Error:
Illigal operands 'volatile union' [ 'unsigned char'
Code:
void vfnInit_normalconversion_adc(unit8_t u8ChannelType, unit32_t u32Channel)
ADC_0.CTR0[u8ChannelType].R = 0x00008606;
[u8ChannelType] → error
Please help me.  Please.....
Thank you.
Khaled
7 返答(返信)
694件の閲覧回数
iansmusical
Contributor V
Hi Khalead,
I'm not sure if this lines makes sense?
From the reference manual there are 3 CTR registers, were you meaning?
  ADC_0.CTR[u8ChannelType].R = 0x00008606;
Can you tell us what exactly you are trying to achieve with that line?
Ian
694件の閲覧回数
khaleadpark
Freescale Cup car-related code.
694件の閲覧回数
khaleadpark
\brief Initialize Adc in scan mode, Configure Adc clock to 32 MHz, set an Adc Channel from a channel type
as a Normal Conversion, and start conversions by settin NSTART to 1.
\param u8ChannelType: defined in Driver_MPC5604B.h as ADC_CHANNEL_TYPE_tag
u32Channel: defined in Driver_MPC5604B.h as ADC_CHANNEL_tag
\return nule
Driver_MPC5604B.h = D_MPC5606B.h
694件の閲覧回数
iansmusical
Contributor V
Hi Khalead,
Thanks for all the information but I think the error:
  Illegal operands 'volatile union' [ 'unsigned char'
is trying to say that the CTR0/1/2 registers can't be accessed as an array with u8ChannelType as the index. In fact the text:
  /* Note the following CTR registers are NOT implemented as an array to */
  /*  try and maintain some concistency through the header file          */
  /*  (The registers are however identical)                              */
kind of backs this up!
I work with the PPC MPC55xx, 56xx and 57xx daily but I don't use the Freescale header file with all the registers defined, so I could be wrong with the interpretation of the error you are seeing!
I'll check my implementation when I'm at work on Monday :-)
Ian
694件の閲覧回数
iansmusical
Contributor V
Hi Khalead,
This is the implementation I use:
#define ADC_0_CTR    (*(volatile unsigned long *) 0x<register address>UL)
And then perhaps something like:
int index;
volatile unsigned long *adc_ctr = &ADC_0_CTR;
for (index = 0; index < 3; index++) {
  adc_ctr[index] = <value>;
Hope it helps :-)
Ian
694件の閲覧回数
khaleadpark
Hi Ian ~
I use a code wrrior 'CW for MCU v10.5'
D_MPC5606.h :
#define CTU_CHANNEL_ANS5 21 /*Adc Channel 37*/
#define CTU_CHANNEL_ANS6 22 /*Adc Channel 38*/
#define CTU_CHANNEL_ANS7 23 /*Adc Channel 39*/
/* Adc channel types values for NCMR and CTR Channel Type parameter */
#define ADC_0_PRECISION_CHANNEL 0 /* Precision channel */
#define ADC_0_EXTENDEDINT_CHANNEL 1 /* Extended Internal channel */
#define ADC_0_EXTERNAL_CHANNEL 2 /* External channel */
/* Adc channel values for NCMR or JCMR Channel Register */
/* Values for Precision Channels */
#define ADC_0_CHANNEL_ANP0 0x00000001 /*Adc Channel 0*/
#define ADC_0_CHANNEL_ANP1 0x00000002 /*Adc Channel 1*/
#define ADC_0_CHANNEL_ANP2 0x00000004 /*Adc Channel 2*/
#define ADC_0_CHANNEL_ANP3 0x00000008 /*Adc Channel 3*/
#define ADC_0_CHANNEL_ANP4 0x00000010 /*Adc Channel 4*/
#define ADC_0_CHANNEL_ANP5 0x00000020 /*Adc Channel 5*/
#define ADC_0_CHANNEL_ANP6 0x00000040 /*Adc Channel 6*/
#define ADC_0_CHANNEL_ANP7 0x00000080 /*Adc Channel 7*/
#define ADC_0_CHANNEL_ANP8 0x00000100 /*Adc Channel 8*/
#define ADC_0_CHANNEL_ANP9 0x00000200 /*Adc Channel 9*/
#define ADC_0_CHANNEL_ANP10 0x00000400 /*Adc Channel 10*/
#define ADC_0_CHANNEL_ANP11 0x00000800 /*Adc Channel 11*/
#define ADC_0_CHANNEL_ANP12 0x00001000 /*Adc Channel 12*/
#define ADC_0_CHANNEL_ANP13 0x00002000 /*Adc Channel 13*/
#define ADC_0_CHANNEL_ANP14 0x00004000 /*Adc Channel 14*/
#define ADC_0_CHANNEL_ANP15 0x00008000 /*Adc Channel 15*/
/* Values fo Extended Internal Channels */
#define ADC_0_CHANNEL_ANS0 0x00000001 /*Adc Channel 32*/
#define ADC_0_CHANNEL_ANS1 0x00000002 /*Adc Channel 33*/
#define ADC_0_CHANNEL_ANS2 0x00000004 /*Adc Channel 34*/
#define ADC_0_CHANNEL_ANS3 0x00000008 /*Adc Channel 35*/
#define ADC_0_CHANNEL_ANS4 0x00000010 /*Adc Channel 36*/
#define ADC_0_CHANNEL_ANS5 0x00000020 /*Adc Channel 37*/
#define ADC_0_CHANNEL_ANS6 0x00000040 /*Adc Channel 38*/
#define ADC_0_CHANNEL_ANS7 0x00000080 /*Adc Channel 39*/
/* PCR for GPIO */
#define GPIO_PIN_A0 0
#define GPIO_PIN_A1 1
#define GPIO_PIN_A2 2
#define GPIO_PIN_A3 3
#define GPIO_PIN_A4 4
#define GPIO_PIN_A5 5
#define GPIO_PIN_A6 6
#define GPIO_PIN_A7 7
#define GPIO_PIN_A8 8
#define GPIO_PIN_A9 9
#define GPIO_PIN_A10 10
#define GPIO_PIN_D0 48
#define GPIO_PIN_D1 49
#define GPIO_PIN_D2 50
#define GPIO_PIN_D3 51
#define GPIO_PIN_D4 52
#define GPIO_PIN_D5 53
#define GPIO_PIN_D6 54
#define GPIO_PIN_E0 64
#define GPIO_PIN_E1 65
#define GPIO_PIN_E2 66
#define GPIO_PIN_E3 67
#define GPIO_PIN_E4 68
#define GPIO_PIN_E5 69
#define GPIO_PIN_E6 70
#define GPIO_PIN_E7 71
#define GPIO_PIN_G10 106
D_ADC.c :
#include "D_MPC5606B.h"
#include "D_ADC.h"
/** Set an Adc channel as normal conversion channel **/
void vfnInit_NormalConversion_Adc(uint8_t u8ChannelType, uint32_t u32Channel)
ADC_0.MCR.R = 0x20000000;/* Initialize ADC0 for scan mode and allow cross triggering */
ADC_0.CTR0[u8ChannelType].R = 0x00008606; /* Conversion times for 32MHz ADClock */ ---> error : Illegal operands 'volatile union' [ 'unsigned char'
ADC_0.MCR.B.ADCLKSEL = 0;
//ADC_0.NCMR0[u8ChannelType].R = ADC_0.NCMR0[u8ChannelType].R | u32Channel; /* Set channel mask as normal conversion mask */
ADC_0.NCMR0[u8ChannelType].R = 0; ------------> error : Illegal operands 'volatile union' [ 'unsigned char'
ADC_0.NCMR0[u8ChannelType].R = ADC_0.NCMR0[u8ChannelType].R | u32Channel; --> error : Illegal operands 'volatile union' [ 'unsigned char'
ADC_0.MCR.B.NSTART=1; /* Start Normal Conversion */
D_ADC.h :
#include "typedefs.h"
\return nule
void vfnInit_NormalConversion_Adc(uint8_t u8ChannelType,uint32_t u32Channel);
MPC5606B.h :
union { /* ADC0 Conversion Timing 0 (Base+0x0094) */
vuint32_t R; /* (precision channels) */
struct {
vuint32_t:16;
vuint32_t INPLATCH:1;
vuint32_t:1;
vuint32_t OFFSHIFT:2;
vuint32_t:1;
vuint32_t INPCMP:2;
vuint32_t:1;
vuint32_t INPSAMP:8;
} B;
} CTR0;
union { /* ADC0 Conversion Timing 1 (Base+0x0098) */
vuint32_t R; /* (standard channels) */
struct {
vuint32_t:16;
vuint32_t:4;
vuint32_t INPCMP:2;
vuint32_t:1;
} B;
} CTR1;
union { /* ADC0 Conversion Timing 2 (Base+0x009C) */
vuint32_t R; /* (Ext multiplexed channels) */
struct {
vuint32_t:16;
vuint32_t:4;
vuint32_t INPCMP:2;
vuint32_t:1;
} B;
} CTR2;
vuint8_t ADC0_reserved5[4]; /* Reserved 4 bytes (Base+0x00A0-0x00A3) */
union { /* ADC0 Normal Conversion Mask 0 (Base+0x00A4) */
struct {
vuint32_t :16;
vuint32_t CH15:1;
vuint32_t CH14:1;
vuint32_t CH13:1;
vuint32_t CH12:1;
vuint32_t CH11:1;
vuint32_t CH10:1;
vuint32_t CH9:1;
vuint32_t CH8:1;
vuint32_t CH7:1;
vuint32_t CH6:1;
vuint32_t CH5:1;
vuint32_t CH4:1;
vuint32_t CH3:1;
vuint32_t CH2:1;
vuint32_t CH1:1;
vuint32_t CH0:1;
} B;
} NCMR0;
union { /* ADC0 Normal Conversion Mask 1 (Base+0x00A8) */
struct {
vuint32_t :4;
vuint32_t CH59:1;
vuint32_t CH58:1;
vuint32_t CH57:1;
vuint32_t CH56:1;
vuint32_t CH55:1;
vuint32_t CH54:1;
vuint32_t CH53:1;
vuint32_t CH52:1;
vuint32_t CH51:1;
vuint32_t CH50:1;
vuint32_t CH49:1;
vuint32_t CH48:1;
vuint32_t CH47:1;
vuint32_t CH46:1;
vuint32_t CH45:1;
vuint32_t CH44:1;
vuint32_t CH43:1;
vuint32_t CH42:1;
vuint32_t CH41:1;
vuint32_t CH40:1;
vuint32_t CH39:1;
vuint32_t CH38:1;
vuint32_t CH37:1;
vuint32_t CH36:1;
vuint32_t CH35:1;
vuint32_t CH34:1;
vuint32_t CH33:1;
vuint32_t CH32:1;
} B;
} NCMR1;
union { /* ADC0 Normal Conversion Mask 2 (Base+0x00AC) */
vuint32_t R; /* (For external mux'd channels) */
struct {
vuint32_t CH95:1;
vuint32_t CH94:1;
vuint32_t CH93:1;
vuint32_t CH92:1;
vuint32_t CH91:1;
vuint32_t CH90:1;
vuint32_t CH89:1;
vuint32_t CH88:1;
vuint32_t CH87:1;
vuint32_t CH86:1;
vuint32_t CH85:1;
vuint32_t CH84:1;
vuint32_t CH83:1;
vuint32_t CH82:1;
vuint32_t CH81:1;
vuint32_t CH80:1;
vuint32_t CH79:1;
vuint32_t CH78:1;
vuint32_t CH77:1;
vuint32_t CH76:1;
vuint32_t CH75:1;
vuint32_t CH74:1;
vuint32_t CH73:1;
vuint32_t CH72:1;
vuint32_t CH71:1;
vuint32_t CH70:1;
vuint32_t CH69:1;
vuint32_t CH68:1;
vuint32_t CH67:1;
vuint32_t CH66:1;
vuint32_t CH65:1;
vuint32_t CH64:1;
} B;
} NCMR2;
vuint8_t ADC0_reserved6[4]; /* Reserved 4 bytes (Base+0x00B0-0x00B3) */
union { /* ADC0 Injected Conversion Mask0 (Base+0x00B4) */
struct {
vuint32_t :16;
vuint32_t CH15:1;
vuint32_t CH14:1;
vuint32_t CH13:1;
vuint32_t CH12:1;
vuint32_t CH11:1;
vuint32_t CH10:1;
vuint32_t CH9:1;
vuint32_t CH8:1;
vuint32_t CH7:1;
vuint32_t CH6:1;
vuint32_t CH5:1;
vuint32_t CH4:1;
vuint32_t CH3:1;
vuint32_t CH2:1;
vuint32_t CH1:1;
vuint32_t CH0:1;
} B;
} JCMR0;
union { /* ADC0 Injected Conversion Mask1 (Base+0x00B8) */
struct {
vuint32_t :4;
vuint32_t CH59:1;
vuint32_t CH58:1;
vuint32_t CH57:1;
vuint32_t CH56:1;
vuint32_t CH55:1;
vuint32_t CH54:1;
vuint32_t CH53:1;
vuint32_t CH52:1;
vuint32_t CH51:1;
vuint32_t CH50:1;
vuint32_t CH49:1;
vuint32_t CH48:1;
vuint32_t CH47:1;
vuint32_t CH46:1;
vuint32_t CH45:1;
vuint32_t CH44:1;
vuint32_t CH43:1;
vuint32_t CH42:1;
vuint32_t CH41:1;
vuint32_t CH40:1;
vuint32_t CH39:1;
vuint32_t CH38:1;
vuint32_t CH37:1;
vuint32_t CH36:1;
vuint32_t CH35:1;
vuint32_t CH34:1;
vuint32_t CH33:1;
vuint32_t CH32:1;
} B;
} JCMR1;
union { /* ADC0 Injected Conversion Mask2 (Base+0x00BC) */
vuint32_t R; /* (external mux'd channels) */
struct {
vuint32_t CH95:1;
vuint32_t CH94:1;
vuint32_t CH93:1;
vuint32_t CH92:1;
vuint32_t CH91:1;
vuint32_t CH90:1;
vuint32_t CH89:1;
vuint32_t CH88:1;
vuint32_t CH87:1;
vuint32_t CH86:1;
vuint32_t CH85:1;
vuint32_t CH84:1;
vuint32_t CH83:1;
vuint32_t CH82:1;
vuint32_t CH81:1;
vuint32_t CH80:1;
vuint32_t CH79:1;
vuint32_t CH78:1;
vuint32_t CH77:1;
vuint32_t CH76:1;
vuint32_t CH75:1;
vuint32_t CH74:1;
vuint32_t CH73:1;
vuint32_t CH72:1;
vuint32_t CH71:1;
vuint32_t CH70:1;
vuint32_t CH69:1;
vuint32_t CH68:1;
vuint32_t CH67:1;
vuint32_t CH66:1;
vuint32_t CH65:1;
vuint32_t CH64:1;
} B;
} JCMR2;
vuint8_t ADC0_reserved7[4]; /* Reserved 4 bytes (Base+0x00C0-0x00C3) */
ADC_CHANNEL_TYPE_tag -----> ????? How can I tag??
error : Illegal operands 'volatile union' [ 'unsigned char' ---->> What mean?
I don't know.
Help me please.
694件の閲覧回数
khaleadpark
Why do errors occur?
I don't know....
