I have an electronic board to drive a car window regulator motor.
It uses an MC9S08AW32CFGE and I have a bug.
I'm looking for a USB interface and software to check the code and reflash if necessary.
Can you recommend an interface and software?
On the pcb there are 6 pins for the interface.
Hi @pnl,
I notice that you have two posts regarding this matter, I will be answering in the other post.
