Implementing Position Algorithms Using Accelerometers Document - DEMO9S08QG8
2,201件の閲覧回数
jmlist
Hello. I had a question regarding the documentation on 'Implementing Positioning Algorithm Using Accelerometers' (http://www.freescale.com/files/sensors/doc/app_note/AN3397.pdf) document. The document on page 7 refers to full source code for the application. However, there are several include files in this source code that are referenced but not included in the document or I can't find (adc.h,buzzer.h, SCItx.h). Does anyone know where these are located or if they can be?
Thanks for your help.
Justin
Message Edited by NLFSJ on 2008-10-15 04:32 PM
3 返答(返信)
413件の閲覧回数
jmlist
anyone? :smileyhappy:
413件の閲覧回数
Gust
Hola jmlist
Te puedo contestar en español? Bueno, espero que si, jeje.... el tema es que esa nota de aplicación la dan como un ejemplo de lo que se puede hacer.... mira este post
Re: Locating header files for source code used in DEMO9S08QG8
413件の閲覧回数
bigmac
Specialist III
Here is the link to which I think the previous post was referring -
Mac
