HC08 and HCS08
HC08 and HCS08
2,460 次查看
TMirnik
What is the difference between HC08 and HCS08 families?
989 次查看
Klined
From a developer's standpoint, HC08's MON08 interface can be a real pain compared to the HCS08's BDM interface.  As stated, HCS08 is far superior.
989 次查看
rocco
Senior Contributor II
Also from a developer's standpoint, HCS08's BDM interface can be a real pain compared to the HC08's MMDS emulator.  As stated, the HCS08 is still superior.
989 次查看
peg
Senior Contributor IV
Hello and welcome to the fora.
Simply put HCS08 (or S08) is a later updated version of the HC08.
Here is an application note about it.
If you know little about either I would suggest you simply forget HC08 ever existed and just look at the S08.
S08 is always better, cheaper and most of the HC08's are dying off.
