Errors when programming in C++
1,177 次查看
cremonezi
I'm trying to create a program in C++ in Code Warrior for MC9S08SE8.
This software has already been created and tested for other uc (and another IDE).
However, when I create it in Code Warrior, several errors have been appeared.
Examples:
1) C1007: Type specifier mismatch
2) C5002: Illegal type
3) C1432: No valid classname specified
4) C1815: getInstance not declared
If anyone can help me, I can send the project with the files created (for more details). :smileyhappy:
Thank you, in advance.
Raphael
489 次查看
CrasyCat
Specialist III
Hello
Which edition of CodeWarrior are you using? Special edition= Standard Edition? Professional edition?
In order to be able to use C++ you need a professional edition.
Also keep in mind that you have limited RAM and ROM resources available on a HC08 microcontroller. Full C++ support is not available on this architecture.
What is supported here is more embedded C++ than full C++.
Some feature of C++ are not supported in embedded C++.
In order to allow us to investigate what is going on here, I would recommend you to submit a service request for that.
Click here to submit a service request.
Make sure to attach a reproducible project and installed product information to the service request.
To generate the required information:
- Start CodeWarrior
- Open the project
- Select "Help" -> "Pack and Go" and follow instructions on the screen.
Attach the generated .zip file to the SR.
CrasyCat
489 次查看
cremonezi
In the installation CD box, there is: "CodeWarrior Development Studio for Microcontrollers Special Edition and HCS12(X) Special Edition". Then, no Professional edition, isn't?
Anyway, I will submit a service request with the project in order to you know the errors...
Thank you for your help.
Cremonezi
