For accelerometers such as MMA7660, by reading registers {XOUT, YOUT, ZOUT} the digital output can be immediately obtained.
However, how to convert these outputs into tilt angles? Namely, what is the relationship between physical tilt angle against the gravity/perpendicular axis, and the sensor’s {XOUT, YOUT, ZOUT} readouts?
It should in general be non-linear. Then what is the formula for conversion? Could Freescale provide some help on this?
Bob
解決済! 解決策の投稿を見る。
Hi Bob,
It is simple trig. Gravity is a vector, so all you need to do is to treat the three axes as vectors, sum them, and the resulting vector is straight down.
Hi Bob,
rocco,
I got it, thanks very much.
