Hello everyone,
I am new for S08 8bit MCU. Now I am working with the MC9S08AW16.
I want to use SCI module to communcate with other MCUs.
I tried to send and receive the data, but failed.
NOW, I have some problems:
I follow the datasheet step: Read the RDRF bit in SCI1S1 register then write the SCI1D register, but the RDRF bit isn't clear.
SO, I want to ask for some advice or 'C' code to do a Software SCI
Thanks.
Solved! Go to Solution.
Hi Mingjun,
Are you using 9 data-bits or parity? Have you tried reading the SCI Control Register 3?
I had that that same problem on the 9S08BG60 when I enabled parity. Parity used a ninth data-bit, and the SCI then required that I read the SCI Control Register 3, where the ninth bit is stored, before it would clear the receive flag. I didn't care about that bit, since the SCI handled parity, but I had to read it anyway. Here is some code:
lda SC1C3 ;read the 9th data but to help clear the interrupt
lda SC1DR ;and then get the real data byte
I found it doesn't matter which order you read the two registers, but the interrupt does not clear until you read the second one.
Hi Mingjun,
Hi Hotchkiss
Thanks for your help. I'm new in S08 MCUs.
The problem is solved by using your advice.
Thank you.
