uboot porting to LPDDR2 on imx6ull
vladimirchernin
Hi!
Our board custom design based on mx6ullevk ref board working with DDR3 500mb
we must use with LPDDR2 Alliance AS4C128M16MD2-25BCN  256mb
in uboot source under /board/freescale/mx6ullevk i see imximage_lpddr2.cfg
seems to be lpddr2 DCD config
Can i use  imximage_lpddr2.cfg with my LPDDR2?
Vladimir
Labels (3)
Hi Vladimir
for new board recommended to run ddr tester
i.MX6/7 DDR Stress Test Tool V2.80
and populate imximage_lpddr2.cfg with new calibration coefficients
found from tester. Use
https://community.nxp.com/docs/DOC-333933
vladimirchernin
Hi Igor!
Please explain if i can use it for any of LPDDR2 from any manufacturer?
is it size dependent?
my DDR is 256MB
Vladimir
no, for every new memory new calibartion coefficients should be found using ddr tester.
