About imx6q-sabresd board
tungho
Hi there,
I can NOT use 'run netboot' command during network booting. The console output is displayed below:
      MX6Q SABRESD U-Boot > run netboot
      ## Error: "netboot" not defined
My question is: Why is 'netboot' NOT defined during this network booting ?? Did I forget to set 'netboot' anywhere ?? If so, how should i set this environment variable ?? What should i set this variable to ??
TH
tungho
This question has been resolved and/or moved to another posts.
Look for this pattern elsewhere in the forum: "About imx6q-sabresd board"
Sorry about this...
TH
tungho
Hi there,
I have been able to network boot my board recently. I basically built the linux image from NXP Yocto Project Community BSP recipe (i.e. bitbake fsl-image-*). The command 'run netboot' is able to run now.
Thanks a bunch,
TH
tungho
Sorry about this...
TH
