Hello everyone,have you ever encountered a problem that imx6q print "Temperature: 0 C, calibration data 0x5604c57d".why the Temperature is 0 C? And what is worse,the imx6q can not launch GPU normally,it will print a lot of error log such as "DMA appears to be stuck at this address " .And then,a moment later,the board will reboot and repeat the err. Does someone have any suggestion about the reason and solution?
Thanks very much!
Original Attachment has been moved to: Serial-COM4_20170725-140707.dat.zip
Please check the memory, using the DDR Stress tool.
i.MX6/7 DDR Stress Test Tool V2.70
Try using the recent BSP.
i.MX 6 / i.MX 7 Series Software and Development Tool|NXP
Also, please take a look at the following thread :
Temperature monitor of IMX6UL doesn't work as expected
Yuri
