I'm building an Autopilot model using Simulink and MPC555. My system has some important data that is found during run-time "not possible to be set in programming as a default values ", and I hope to find a way "a special Simulink-block or custom coding" to save these data into the non-volatile memory, so I can restore it when I restart my own system(i.e. I'm asking if there is a way to allow my code to write to Flash memory and reread what was written after restarting).
my colleague sent you an answer in this thread:
https://community.nxp.com/thread/444880
Martin
