Thanks for the answer Carsten.
Yes, I know/knew about the info in the docs you mention. But I want to have this info in the form of a table in eg Excel. What I am about to do is to manually copy all the data from the PDF into Excel. So before I do that tedious job I ask if there is already such a table/ someone esle created it. I think I've seen this type of an overview in other manufacturers. And I suppose internally NXP must keep this info in the form I am looking for.
example
Hi Adam,
Please try using LPCXpert V3.2: PinMux and Software Configuration Tool for the LPC Families of Micro-Controllers
Please let me know if this helps.
Sol
Thank you Sol,
very nice tool and there is a newer version 3.3
LPCXpert V3.3: Software Expert Tool for the LPC Family of Micro-Controllers
Not exactly what I asked for (excel table with the list of pins) but I did not know about LPCXpert and it is great but...
it seems as this tool does not work well for LPC11c24, I try to configure CAN and it does not work. Here:
Now I want to configure CAN pins and it is not possible. Anything I select from the drop down menu it will not be applied. Whatever I do it always stays like this :
And pins 19 and 20 (again CAN interface) are not available. When I go through the list of pins they are missing :
and when I press 'next' I get pin 21:
This tool seems to be incomplete or am I doing sth wrong ?
CAN TX and CAN RX can not be relocated, they are fixed on pin 19 and 20.
Correct, thank you Carsten.
I have successfully used the datasheet for exactly that: http://www.nxp.com/documents/data_sheet/LPC11CX2_CX4.pdf
And also the Users Guide: http://www.nxp.com/documents/user_manual/UM10398.pdf
I think you will find all the info in these ?
