Documentation says:
The kernel module version of graphics used on the system can be found by running the following command on the board:
dmesg | grep Galcore
I got response:
root@imx6qpsabreauto:~# dmesg | grep Galcore
[ 0.836271] Galcore version 5.0.11.41671
The user-side GPU drivers version of graphics can be displayed using the following command on the board:
grep VERSION /usr/lib/libGAL*
root@imx6qpsabreauto:~# grep VERSION /usr/lib/libGAL*
Binary file /usr/lib/libGAL.so matches
I'm not getting version number: What's the GPU drivers version?
Nope your link did not help.
