Does MQX support openSSL? I have found some links mentioning cyaSSL. can I please get any support for building openssl and libwebsocket for MQX application for Kinetis?
Hello Preet Mehta:
Unfortunately the SSL support is available only through third parties. For SSL, I recommend the customer evaluate options like cyaSSL from www.wolfssl.com. It is compatible with MQX RTOS and supports Kinetis. However, not all Kinetis derivatives may be supported and the versions of the tools and MQX RTOS software may be a few versions old.
For MQX classic:
CyaSSL embedded SSL now available for MQX!
For MQX with KSDK:
Now Available: CyaSSL for MQX RTCS
How To: Build and run the MQX HTTPS Server example with CyaSSL
Sol
