What is a License Control Panel (LCP) Account?
lpcware-support
Senior Contributor I
Note: This FAQ applies to LPCXpresso IDE (Pro Edition) only.
Our licensing partner - Softworks has replaced the License Control Panel scheme with the web portal 'mySoftwareLicense'.
To access the new web portal through LPCXpresso IDE goto: Help -> Activate -> mySoftwareLicense web portal (Pro Edition)...
Further information regarding the features of this portal are detailed in the FAQ:
Central administration of activation codes.
