Solved! Go to Solution.
thanks for your help.
I have solved this problem by this card:
thanks again.
Hi Zhu,
Have you tried using the P&E recovery utility? Take a look to the following post created by our colleague Erich Styger, it explains how to use it to recover your boards:
Bricking and Recovering FRDM-KL25Z Boards: Reset, SWD Clock and Low Power | MCU on Eclipse
Please notice that you will need an external probe like a Multilink.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
