Where is the hv.dts file in Freescale SDK 1.6 for P4080DS
peterzheng
I was trying to create 8 partitions on P4080DS using hypervisor.  I was following the documentation provided by Yiping.
https://community.freescale.com/docs/DOC-102249
However, I have trouble locate the hv.dts file. Could you help me with this issue? where is this file in the SDK after uncompress the ISO?
Peter Zheng
lunminliang
Please check in attached hv-cfg-fsl-sdk-v1.6.tar.gz for SDK, under the path /p4080ds/R_PPSXX_0xe/hv-2p-Lnx-Lnx/hv.dts.
Also you can download from below for SDK1.6:
sdk/hv-cfg.git - Freescale PowerPC Hypervisor Config Tree
root/p4080ds/R_PPSXX_0xe/hv-2p-lnx-lnx/hv.dts
Is this what you want?
Lunmin
lunminliang
Lunmin
peterzheng
Hi Lunmin,
Thank you for your help. Could you help me take a look at another problem?
how to create 8 partitions using hypervisor in P4080DS
Thanks & Regards,
Peter Zheng
lunminliang
Sure, I'll have a look soon later.
Lunmin
peterzheng
Hi Lunmin,
I was pointing you to the wrong question. Sorry about that. Can you take a look at this particular question?
How to partition the L3 Cacahe of P4080 using CodeWarrior?
Thank you very much for your time and help!
Peter
