Could someone advice suggested BT & Wifi module for IMX SABRE AI?
I see that the Bluetooth and Wi-Fi module are optional as well as the Apple identification chip for SABRE AI. Is it possible to buy also these optional directly from Freescale or need to go through distributor?
Solved! Go to Solution.
Hi Shun, one can use Atheros chips (for example AR6003 WiFi)
or Silex modules
141-00207-509C_iMX6X_SX-SDCAN_QSG.pdf
Regarding Apple I am not sure where did you find references to it.
or Silex modules
