After I pass to MQX 4.0.2, I have nandflash size problem. I get "Free disk space: 126212096 bytes" message instead of 252694528.
I installed mqx 4.0.2 and new ffs. I have done same steps but now I get smaller disk size. Do you have any idea.I use TWRK60f120m. I was successful on mqx 4.0.1.
previous discussion
Change size of FFS drive (MQX 4.0.1, TWR-K70)
nandflash_wl_ffs.h
#define NANDFLASH_1ST_DATA_DRIVE_SIZE_IN_BLOCK 1937
#define NANDFLASH_1ST_DATA_DRIVE_START_BLOCK 110
Formating... | |
Done. Volume name is |
Okan ERCAN
Hi Okan ERCAN,
I am facing the same problem. Did you ever figure it out?
A question is where did you download the FFS_MQX 4.0.1, because I can only find the FFS patch for MQX4.0.2?
Thank you.
-Daniel
