I am using LSDK flexbuild1809 on Ubuntu 18.04 running in a VirtualBox VM.
My target is LS2088ARDB.
I run the following command:
flex-builder -i autobuild-log -a arm64 -m ls2088ardb
INSTRUCTION: mklinux
DESTARCH: arm64
CONFIGLIST:build_lsdk.cfg
[sudo ] password for labadmin: //once given password
umount: mntrd: not mounted.
//And stopped is there any thing i can check to make sure my lsdk_linux_arm64_tiny.itb is generated.
Hi ranga.yn@radisys.com,
This community space do not cover the topic you need assistance on.
Please create new thread QorIQ Processing Platforms on the community space OR new NXP support case according to following procedure:https://community.nxp.com/docs/DOC-329745
Hope this helps,
Marius
