We going to design our custom board using iMX8MQ.
And we will use micron lpddr4 RAM which part number is "MT53D1024M32D4DT-053 AIT:D"
As I found one communication on the community at below link.
u-boot fails to boot with 4GB RAM on i.MX8mq
So I just want to confirm there is any issue with 4GB lpddr4 RAM with the iMX8MQ processor? If possible, so can I use that part and able to use 4GB RAM?
Best,
Nirmal
Solved! Go to Solution.
Hi Nirmal
linux memory size is controlled by u-boot in i.MX8M software. One can try
attached u-boot patch. For new board recommended to follow Chapter 4 How to bring up a
new MX8M board MX8M_DDR_Tool_User_Guide document included in ddr test package.
i.MX8MSCALE DDR Tool Release
Hi Nirmal
