Hi :
I'm porting android8.1.3 to MX8MD. But feil to boot up uboot: mfgtool stop at "Jumping to OS image"(none log print out).
My platform is using DDR4, and the ddr_stress_test can pass 1000M to 1400M.
uboot config: I have tried both "mx8mq_evk_android_defconfig" and "imx8mq_ddr4_arm2_defconfig".
ddr4 firmware is from mx8m_ddr_tool_v1.0.
all others are default. and replace firmware/imx-boot-imx8mqevk-sd.bin-flash_evk after builded.
Is there anyone can help me ?
To build the mfgtool firmware, you can refer to this.
You can download the Android BSP from here:
Download the Android O8.1.0 for i.MX 8MQuad GA and the BSP document Android O8.1.0_1.3.0 8MQ GA Documentation
