GStreamer Miscellaneous
Dumping the pipeline elements into a image file
# On target, run the pipeline
$ export GST_DEBUG_DUMP_DOT_DIR=<folder where dot files are created>
$ gst-launch playbin2 uri=file://${avi}
$ # Move the .dot files to a host machine (scp, etc)
# On Host
# dot command is part the the graphviz package
Querying which elements are being used on a gst-launch commandGST_DEBUG=GST_ELEMENT_FACTORY:3 gst-launch playbin2 uri=file://`pwd`/<media file>
Interrupting a gst-launch process running in the background
kill -INT $PID
# where $PID is the process ID
Using only SW codecs
# Backup and remove
$ find /usr/lib/gstreamer-0.10 -name "libmfw*" | grep -v sink | xargs tar cvf /libmfw_gst.tar
$ find /usr/lib/gstreamer-0.10 -name "libmfw*" | grep -v sink | xargs rm
# Run your pipeline. This time SW codecs are used
$ gst-launch playbin2 uri=file://`pwd`/media_file
# To 'install' FSL plugins again, just untar the file
$ cd / && tar xvf libmfw_gst.tar && cd -
# then run your pipeline. This time HW codecs are used
ラベル(2)
コメント
The instructions for 'Using only SW codecs' don't work for me.  I have a SabreSD board with i.MX6Q CPU and 4.0.0 version of the Linux SDK with patched ffmpeg plugins installed.  Here is my output:
root@freescale ~$ gst-launch playbin2 uri=file:///root/RecordedTs-coreel-720p5994.ts
Pipeline is PREROLLING ...
WARNING: from element /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: No decoder available for type 'video/mpegts, systemstream=(boolean)true, packetsize=(int)188'.
Additional debug info:
gsturidecodebin.c(867): unknown_type_cb (): /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0
ERROR: from element /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20: Your GStreamer installation is missing a plug-in.
gstdecodebin2.c(3233): gst_decode_bin_expose (): /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20:
no suitable plugins found
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
root@freescale ~$ gst-launch playbin2 uri=file:///root/sample_mpeg4.mp4
WARNING: from element /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: No decoder available for type 'audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1290, rate=(int)32000, channels=(int)2'.
ERROR: from element /GstPlayBin2:playbin20/GstPlaySink:playsink0: The autovideosink element is not working.
gstplaysink.c(1353): gen_video_chain (): /GstPlayBin2:playbin20/GstPlaySink:playsink0
Try these steps:
rm .gstreamer-0.10/registry.arm.bin # this is done to force plugins reloading
gst-inspect | grep ff # To check if ffmpeg plugins are there
gst-launch playbin2 ....
Actually, you may need the Freescale video sinks, so do not move/remove these. Let me know if it works.
Leo
Ok, I removed all libmfw_* EXCEPT libmfw_gst_isink.so and libmfw_gst_v4lsink.so and that works. Thanks.
I have updated the recipe! Thanks!
Leo
%3CLINGO-SUB%20id%3D%22lingo-sub-1117877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGStreamer%E3%81%9D%E3%81%AE%E4%BB%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E8%A6%81%E7%B4%A0%E3%82%92%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%83%80%E3%83%B3%E3%83%97%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%A7%E3%80%81%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20export%20GST_DEBUG_DUMP_DOT_DIR%3D%3CFOLDER%20where%3D%22%22%20dot%3D%22%22%20files%3D%22%22%20are%3D%22%22%20created%3D%22%22%3E%3C%2FFOLDER%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20gst-launch%20playbin2%20uri%3Dfile%3A%2F%2F%24%7Bavi%7D%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20%23%20.dot%E3%82%92%E7%A7%BB%E5%8B%95%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%B8%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB(SCP%E3%81%AA%E3%81%A9)%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%3CBR%20style%3D%22color%3A%20%23000000%3B%22%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E3%83%9B%E3%82%B9%E3%83%88%E4%B8%8A%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Edot%20%3CDOT%20file%3D%22%22%3E%20-Tpng%20-o%20out.png%3C%2FDOT%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20dot%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%20graphviz%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3Egst-launch%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E8%A6%81%E7%B4%A0%E3%81%AE%E3%82%AF%E3%82%A8%E3%83%AA%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3EGST_DEBUG%3DGST_ELEMENT_FACTORY%3A3%20gst-launch%20playbin2%20uri%3Dfile%3A%2F%2F'pwd'%2F%3CMEDIA%20file%3D%22%22%3E%3C%2FMEDIA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8Bgst-launch%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AE%E4%B8%AD%E6%96%AD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Ekill%20-INT%20%24PID%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E3%81%93%E3%81%93%E3%81%A7%E3%80%81%24PID%20%E3%81%AF%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20ID%20%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3ESW%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E3%83%90%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%A8%E5%89%8A%E9%99%A4%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20find%20%2Fusr%2Flib%2Fgstreamer-0.10%20-name%20%22libmfw*%22%20%7Cgrep%20-v%20%E3%82%B7%E3%83%B3%E3%82%AF%20%7Cxargs%20tar%20cvf%20%2Flibmfw_gst.tar%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20find%20%2Fusr%2Flib%2Fgstreamer-0.10%20-name%20%22libmfw*%22%20%7Cgrep%20-v%20%E3%82%B7%E3%83%B3%E3%82%AF%20%7Cxargs%20rm%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BB%8A%E5%9B%9E%E3%81%AFSW%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20gst-launch%20playbin2%20uri%3Dfile%3A%2F%2F'pwd'%2Fmedia_file%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20FSL%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E5%86%8D%E5%BA%A6%E3%80%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%80%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A7%A3%E5%87%8D%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20cd%20%2F%20%26amp%3B%26amp%3B%20tar%20xvf%20libmfw_gst.tar%20%26amp%3B%26amp%3B%20cd%20-%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BB%8A%E5%9B%9E%E3%81%AFHW%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%24%20gst-launch%20playbin2%20uri%3Dfile%3A%2F%2F'pwd'%2Fmedia_file%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1117877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%E3%81%9D%E3%81%AE%E4%BB%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%AC%E3%82%B7%E3%83%94%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!%E6%84%9F%E8%AC%9D%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%E3%81%9D%E3%81%AE%E4%BB%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AFlibmfw_gst_isink.so%E3%81%A8libmfw_gst_v4lsink.so%E3%82%92%E9%99%A4%E3%81%8F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AElibmfw_*%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E6%84%9F%E8%AC%9D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%E3%81%9D%E3%81%AE%E4%BB%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%82%B7%E3%83%B3%E3%82%AF%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%82%92%E7%A7%BB%E5%8B%95%2F%E5%89%8A%E9%99%A4%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A7%81%E3%81%AB%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%E3%81%9D%E3%81%AE%E4%BB%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E3%81%8A%E8%A9%A6%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Erm%20.gstreamer-0.10%2Fregistry.arm.bin%20%23%20%E3%81%93%E3%82%8C%E3%81%AF%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E5%BC%B7%E5%88%B6%E7%9A%84%E3%81%AB%E3%83%AA%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3EGST%E6%A4%9C%E6%9F%BB%20%7Cgrep%20ff%20%23%20ffmpeg%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%3C%2FP%3E%0A%3CP%3EGST%20-%E3%83%AD%E3%83%BC%E3%83%B3%E3%83%81%E3%83%97%E3%83%AC%E3%82%A4%E3%83%93%E3%83%B32%20....%20%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%E3%81%9D%E3%81%AE%E4%BB%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%80%8CSW%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%80%8D%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%8C%E7%A7%81%E3%81%AB%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82i.MX6Q%20CPU%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FSabreSD%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9Fffmpeg%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9FLinux%20SDK%E3%81%AE4.0.0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20gst-launch%20playbin2%20uri%3Dfile%3A%2F%2F%2Froot%2FRecordedTs-coreel-720p5994.ts%3C%2FP%3E%3CP%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3EPipeline%20is%20PREROLLING%20...%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3A%E8%A6%81%E7%B4%A0%2F%20GstPlayBin2%3Aplaybin20%20%2F%20GstURIDecodeBin%3Auridecodebin0%E3%81%8B%E3%82%89%3A%E3%82%BF%E3%82%A4%E3%83%97%20'video%20%2F%20mpegts%E3%80%81systemstream%20%3D(boolean)true%E3%80%81packetsize%20%3D%20(int)188'%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%83%85%E5%A0%B1%3A%3C%2FP%3E%3CP%3Egsturidecodebin.c(867)%3A%20unknown_type_cb%20()%20%3A%20%2FGstPlayBin2%3Aplaybin20%2FGstURIDecodeBin%3Auridecodebin0%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E8%A6%81%E7%B4%A0%2F%20GstPlayBin2%3Aplaybin20%20%2F%20GstURIDecodeBin%3Auridecodebin0%20%2F%20GstDecodeBin2%3Adecodebin20%E3%81%8B%E3%82%89%3AGStreamer%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%AB%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%83%85%E5%A0%B1%3A%3C%2FP%3E%3CP%3Egstdecodebin2.c(3233)%3Agst_decode_bin_expose()%3A%2F%20GstPlayBin2%3Aplaybin20%20%2F%20GstURIDecodeBin%3Auridecodebin0%20%2F%20GstDecodeBin2%3Adecodebin20%3A%3C%2FP%3E%3CP%3E%E9%81%A9%E5%88%87%E3%81%AA%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%83%97%E3%83%AA%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%92%E6%9C%9B%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%20NULL%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20...%3C%2FP%3E%3CP%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20gst-launch%20playbin2%20uri%3Dfile%3A%2F%2F%2Froot%2Fsample_mpeg4.mp4%3C%2FP%3E%3CP%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3EPipeline%20is%20PREROLLING%20...%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3A%E8%A6%81%E7%B4%A0%2FGstPlayBin2%3Aplaybin20%2FGstURIDecodeBin%3Auridecodebin0%E3%81%8B%E3%82%89%3A%E3%82%BF%E3%82%A4%E3%83%97%20'audio%20%2F%20mpeg%E3%80%81mpegversion%20%3D(int)4%E3%80%81framed%20%3D(boolean)true%E3%80%81stream-format%20%3D(string)raw%E3%80%81level%20%3D(string)2%E3%80%81base-profile%20%3D(string)lc%E3%80%81profile%20%3D(string)lc%E3%80%81codec_data%3D(buffer)1290%E3%80%81rate%20%3D(int)32000%E3%80%81channels%20%3D(int)2'%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%83%85%E5%A0%B1%3A%3C%2FP%3E%3CP%3Egsturidecodebin.c(867)%3A%20unknown_type_cb%20()%20%3A%20%2FGstPlayBin2%3Aplaybin20%2FGstURIDecodeBin%3Auridecodebin0%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E8%A6%81%E7%B4%A0%2F%20GstPlayBin2%E3%81%8B%E3%82%89%3Aplaybin20%20%2F%20GstPlaySink%3Aplaysink0%3Aautovideosink%E8%A6%81%E7%B4%A0%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%83%85%E5%A0%B1%3A%3C%2FP%3E%3CP%3Egstplaysink.c(1353)%3Agen_video_chain%20()%3A%20%2FGstPlayBin2%3Aplaybin20%2FGstPlaySink%3Aplaysink0%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%83%97%E3%83%AA%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%92%E6%9C%9B%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%20NULL%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20...%3C%2FP%3E%3CP%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-28-2012 02:21 PM
更新者:
