Using LPC55S69 with SE050 and CLRC663plus for Secure Access to industrial IOT
DISCLAIMER APPLICABLE TO THIS DOCUMENT CONTENTS:
This post contains a guide of how to use LPC55S69 demoboard with other NXP demoboards to demonstrate Access control using NFC, one embedded secure element and an MCU (see picture below). A ready to use package including preparation of a secure element, and of a MIFARE DESFire EV2 card can be used as 3-step authentication example using symmetric AES keys; a session key will be generated inside SE050 which will be exported to LPC55S69 which will handle contactless communication thru CLRC663 plus frontend.
This document is structured as follows:
Hardware Requirements:
Following hardware is required to run the project:
  1. LPC55S69-EVK development board.
  2. OM-SE050ARD development board.
  3. CLEV6630B board or BLE-NFC-V2 board.
1. Overview of LPC55S69-EVK:pastedImage_2.png
The LPCXpresso55S69 development board provides the ideal platform for evaluation of and development with the LPC55S6x MCU based on the Arm® Cortex®-M33 architecture. The board includes a high performance onboard debug probe, audio subsystem and accelerometer, with several options for adding off-the-shelf add-on boards for networking, sensors, displays and other interfaces.
The LPCXpresso55S69 is fully supported by the MCUXpresso suite of tools, which provides device drivers, middleware and examples to allow rapid development, plus configuration tools and an optional free IDE. MCUXpresso software is compatible with tools from popular tool vendors such as Arm and IAR, and the LPCXpresso55S69 may also be used with the popular debug probes available from SEGGER and P&E Micro.
2. Overview of OM-SE050ARD demoboard:
The OM-SE050ARD is the flexible and easy-to-use development kit for the EdgeLock SE050 Plug & Trust product family. It can be used in various ways for example via the Arduino interface compatible to any board featuring an Arduino compatible header, including many i.MX, LPC and Kinetis boards, or via a direct I2C connection. This kit allows evaluation of the SE050 product family features and simplifies the development of secure IoT applications. More information can be found in the respective Application Note AN12395.
2.1 Connections between OM-SE050ARD and LPC55S69 EVK
OM-SE050ARD
LPC55S69 (Conn.# - Pin #)
Port
Function Name
SE_SDA (J22-1)
P24-6 also P17-3
PIO1_21
FC4_I2C_SDA_ARD
SE_SCL (J22-4)
P24-5 also P17-1
PIO1_20
FC4_I2C_SCL_ARD
+5V_PC (J22-2)
VDD_TARGET
GND (J22-3)
GND
2.2 Jumper settings on OM-SE050ARD to connect it to LPC55S69 EVK
Connect SE050 to LPC55S Arduino stackable headers and change jumper J14 as:
This connects SE_VDD directly to 3V3 and bypasses enable signal. This is required because enable pin on LPC55S coincides with Silex-2401 SPI pins so we cannot use SE_EN signal to drive SE_VDD.
3. Overview of NFC Front end boards working with LPC55S69 EVK board for this example:
3.1 BLE-NFC-V2:
It is easier to use the BLE-NFC-V2 board since less changes have to made on the board as compared to the CLEV6630B board.
The following figure shows the pin mapping between the two boards. It is advisable to add a pull-up resistor (4k7 to VCC) on CLRC663 plus signal IRQ.
3.2 CLEV6630B board:
The CLEV6630B board consists of CLRC663 plus (NFC frontend) connected by default to an LPC1769 µC via SPI. However, the board is made in such a way that the LPC1769 MCU can be bypassed to connect to an external MCU (in our case the LPC55S69) easily. For doing so:
  • Six resistors from the board need to be removed. These are highlighted in red in the Figure 1:pastedImage_14.png
  • Use the SPI pin connectors available on the left-hand side, on the board edge to connect to external MCU (LPC55S69 in this case)
  • Solder jumper wires onto the following pins of CLEV6630B Board:
    • GND
    • IRQ
    • CLRC_NRST
    • SSEL
    • MOSI
    • MISO
    • SCK
    • IF0
    • IF1
The CLEV6630B is shown in Figure 2 after the required changes have been made to it (Removal of resistors and soldering of wires).
Now connect the two boards as follows:
Signal function
LPC55S69 (conn. # - Pin #)
Port
CLEV6630B
MOSI
P17-10
PIO0_20
MOSI
MISO
P17-12
PIO0_19
MISO
SPI SCK
P17-14
PIO0_21
SCK
SPI CSEL
P17-6
PIO1_11
SSEL
RESET
P18-11
PIO0_15
CLRCL_NRST
IRQ
P18-3
PIO1_10
IRQ
GND
P17-7
GND
 As final touch to this demonstrator, one LCD display will be added in order to show "access control" check result when approaching a MIFARE DESFire EV2 card to the Reader antenna, without the use of a computer console.
Connection between LPC55S69 board and LCD Display:
TFT
LPC55S69 (Jumper # - Pin #)
Port
     SPI_CLK
D13 (P17-9)
PIO1_2
     SPI_MISO
D12 (P17-11)
PIO1_3
     SPI_MOSI
D11 (P17-13)
PIO0_26
     SPI_CS_TFT
D10 (P17-15)
PIO1_1
     GPIO_LCD_BL
D9 (P17-17)
PIO1_5
     GPIO_LCD_DC
D7 (P18-1)
PIO1_9
5V
5V
GND
GND
Click here to order 2.8 inch TFT Display from Waveshare: P/N: 2.8 inch TFT Touch Shield Brand
4. Running "Secure Access to Industrial IOT demo" at LPC55S69:
  1. If this is the first time you’re using LPC55S69-EVK board, follow the getting started guide first à  LPC55S69-EVK | NXP . Make sure to install the SDK package for LPC55S69-EVKboard which is required for the project below to run.
  2. Download the ‘demobinaries.zip' package which you will find attached to this post. This zip file contains 2 bin files:
    1. ex_prepareCard.bin - upload this binary file to LPC55S69 when you need to prepare a MIFARE DESFire EV2 card with suitable application and AES keys used for demonstrator. Upload bin file to LPC55S69 by using MCUxpresso. Just place a virgin card on top of Reader antenna, and reset MCU board by clicking on "RESET KEY" push button.
    2. ex_prepareSe050.bin - upload this binary file to LPC55S69 when you need to prepare a new SE050 with suitable AES keys to be used in this demo. Just  upload binary using MCUxpresso; connect a virgin OM-SE050ARD on LPC55S69 arduino connectors, connect micro USB connector to MCU board, and reset MCU by clicking "RESET KEY".
  3. After steps 2.1 and 2.2 have been done to obtain preparation of one Secure element as well as preparation of one MIFARE DESFire EV2 card, then upload the next bin file to LPC55S69 using MCUxpresso: ex_Ev2Auth_se05x.bin
  4. Alternatively, you can import the whole project in your MCUxpresso environment.
    1. Download the file EmbeddedWorld2019DemoLatest.zip at end of this page.
    2. Import this zip file project in MCUxpresso environment
  5. Now that the package has been imported to the MCUXpresso IDE (via drag and drop), click on Debug icon from the Quickstart panel to begin a debug session. Once the debug session has started, click on the run icon to run the code:
  6. PICTURE TO BE UPDATED
  7. MCUXPRESSO PICTURE TO BE UPDATED
  8. The project should be running now. The project contains a closed loop that tries to check presence of a card on top of Reader. Here is how the output looks like in LCD Display.
  9. Press the button reset, and you will see the text "Secure Access to Industrial IOT demo 2019"
  10. PICTURE TO BE UPDATED
  11. Then press the button "Wake-up". Afterwards NFC reader will enter in a loop in which he will look for a card to authenticate. If there are no cards, he will soon show the red allert with text "Access denied"
  12. Bring any NFC card near the frontend’s antenna (or in presence of no card) LCD display will show a message in RED "ACCESS DENIED".
  13. PICTURE TO BE UPDATED
  14. Only in case the "prepared DESFire EV2" card is placed on top of reader, in the picture below, we can see message in GREEN "ACCESS GRANTED"
  15. PICTURE TO BE UPDATED.
Available Resources:
  1. Porting NFC Reader Library to i.MX RT1050. (Detailed Description of porting)
    https://community.nxp.com/docs/DOC-341843
  2. LPC55S69
    https://www.nxp.com/products/processors-and-microcontrollers/arm-based-processors-and-mcus/lpc-corte...
  3. BLE-NFC-V2
    https://www.nxp.com/products/identification-security/rfid/nfc-hf/nfc-readers/clrc663-iplus-i-and-qn9...
  4. CLEV6630B Product Information|NXP
  5. SE050: www.nxp.com/SE050
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1105215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE050%E3%81%8A%E3%82%88%E3%81%B3CLRC663plus%E3%81%A8LPC55S69%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%94%A3%E6%A5%AD%E7%94%A8IOT%E3%81%AB%E5%AE%89%E5%85%A8%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSTRONG%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E5%85%8D%E8%B2%AC%E4%BA%8B%E9%A0%85%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F91372iEA4C3E8F7225D912%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AB%E3%81%AF%E3%80%81LPC55S69%E3%83%87%E3%83%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BB%96%E3%81%AENXP%E3%83%87%E3%83%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81NFC%E3%80%811%E3%81%A4%E3%81%AE%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A8%E3%83%AC%E3%83%A1%E3%83%B3%E3%83%88%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3MCU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E5%88%B6%E5%BE%A1%E3%82%92%E7%A4%BA%E3%81%99%E6%96%B9%E6%B3%95%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%E4%B8%8B%E3%81%AE%E5%9B%B3%E3%82%92%E5%8F%82%E7%85%A7)%E3%80%82%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A8%E3%83%AC%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A8MIFARE%20DESFire%20EV2%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E6%BA%96%E5%82%99%E3%82%92%E5%90%AB%E3%82%80%E3%81%99%E3%81%90%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E3%80%81%E5%AF%BE%E7%A7%B0AES%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F3%E6%AE%B5%E9%9A%8E%E8%AA%8D%E8%A8%BC%E3%81%AE%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%AD%E3%83%BC%E3%81%AFSE050%E5%86%85%E3%81%A7%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%80%81CLRC663%20%3CEM%3E%E3%83%97%E3%83%A9%E3%82%B9%3C%2FEM%3E%20%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%82%92%E4%BB%8B%E3%81%97%E3%81%9F%E9%9D%9E%E6%8E%A5%E8%A7%A6%E9%80%9A%E4%BF%A1%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8BLPC55S69%E3%81%AB%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22LPC55S69%20SE050%20CLEV663B.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LPC55S69%20SE050%20CLEV663B.jpg%22%20style%3D%22width%3A%20943px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F93485i2878DFC303BE6B67%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22LPC55S69%20SE050%20CLEV663B.jpg%22%20alt%3D%22LPC55S69%20SE050%20CLEV663B.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ELPC55S69%20SE050%20CLEV663B.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FUsing-LPC55S69-with-SE050-and-CLRC663plus-for-Secure-Access-to%2Fta-p%2F1105215%23toc-hId-380635888%22%20target%3D%22_blank%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A6%81%E4%BB%B6%3A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FUsing-LPC55S69-with-SE050-and-CLRC663plus-for-Secure-Access-to%2Fta-p%2F1105215%23toc-hId--1426818575%22%20target%3D%22_blank%22%3E1.%20LPC55S69-EVK%E3%81%AE%E6%A6%82%E8%A6%81%3A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FUsing-LPC55S69-with-SE050-and-CLRC663plus-for-Secure-Access-to%2Fta-p%2F1105215%23toc-hId-1060694258%22%20target%3D%22_blank%22%3E2.%20OM-SE050ARD%E3%83%87%E3%83%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%A6%82%E8%A6%81%3A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FUsing-LPC55S69-with-SE050-and-CLRC663plus-for-Secure-Access-to%2Fta-p%2F1105215%23toc-hId-1751255732%22%20target%3D%22_blank%22%3E2.1%20OM-SE050ARD%E3%81%A8LPC55S69%20EVK%E3%81%AE%E6%8E%A5%E7%B6%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FUsing-LPC55S69-with-SE050-and-CLRC663plus-for-Secure-Access-to%2Fta-p%2F1105215%23toc-hId--56198731%22%20target%3D%22_blank%22%3E2.2%20OM-SE050ARD%E3%82%92LPC55S69%20EVK%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E8%A8%AD%E5%AE%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FUsing-LPC55S69-with-SE050-and-CLRC663plus-for-Secure-Access-to%2Fta-p%2F1105215%23toc-hId--66701835%22%20target%3D%22_blank%22%3E3.%20%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AFLPC55S69%20EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E9%80%A3%E6%90%BA%E3%81%99%E3%82%8BNFC%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%A6%82%E8%A6%81%3A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FUsing-LPC55S69-with-SE050-and-CLRC663plus-for-Secure-Access-to%2Fta-p%2F1105215%23toc-hId--1183594824%22%20target%3D%22_blank%22%3E3.1%20BLE-NFC-V2%3A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FUsing-LPC55S69-with-SE050-and-CLRC663plus-for-Secure-Access-to%2Fta-p%2F1105215%23toc-hId-1303918009%22%20target%3D%22_blank%22%3E3.2%20CLEV6630B%E3%83%9C%E3%83%BC%E3%83%89%3A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FUsing-LPC55S69-with-SE050-and-CLRC663plus-for-Secure-Access-to%2Fta-p%2F1105215%23toc-hId-1293414905%22%20target%3D%22_blank%22%3E4.%20LPC55S69%E3%81%A7%E3%80%8CSecure%20Access%20to%20Industrial%20IOT%E3%83%87%E3%83%A2%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FUsing-LPC55S69-with-SE050-and-CLRC663plus-for-Secure-Access-to%2Fta-p%2F1105215%23toc-hId--766303897%22%20target%3D%22_blank%22%3E%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3A%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%0A%3CH1%20id%3D%22toc-hId-380635888%22%20id%3D%22toc-hId-1304188821%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A6%81%E4%BB%B6%3A%3C%2FH1%3E%0A%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3COL%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3ELPC55S69-EVK%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%80%82%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3EOM-SE050ARD%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%80%82%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3ECLEV6630B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AFBLE-NFC-V2%E3%83%9C%E3%83%BC%E3%83%89%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CH1%20id%3D%22toc-hId--1426818575%22%20id%3D%22toc-hId--503265642%22%3E1.%20LPC55S69-EVK%E3%81%AE%E6%A6%82%E8%A6%81%3A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20258px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F93484iDD146D47C167913E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FH1%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-based-processors-and-mcus%2Flpc-cortex-m-mcus%2Flpc5500-cortex-m33%2Flpcxpresso55s69-development-board%3ALPC55S69-EVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELPCXpresso55S69%3C%2FA%3E%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81Arm%C2%AE%20Cortex-M33%C2%AE%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FLPC55S6x%20MCU%E3%81%AE%E8%A9%95%E4%BE%A1%E3%81%A8%E9%96%8B%E7%99%BA%E3%81%AB%E6%9C%80%E9%81%A9%E3%81%AA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E3%80%81%E9%AB%98%E6%80%A7%E8%83%BD%E3%81%AE%E3%82%AA%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%83%BB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%BB%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%BB%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%80%81%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%A8%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E7%94%A8%E3%81%AE%E6%97%A2%E8%A3%BD%E3%81%AE%E3%82%A2%E3%83%89%E3%82%AA%E3%83%B3%E3%83%BB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E7%94%A8%E6%84%8F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ELPCXpresso55S69%E3%81%AF%E3%80%81%E8%BF%85%E9%80%9F%E3%81%AA%E9%96%8B%E7%99%BA%E3%82%92%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%99%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%80%81%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E6%A7%8B%E6%88%90%E3%83%84%E3%83%BC%E3%83%AB%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E7%84%A1%E6%96%99IDE%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8BMCUXpresso%E3%83%84%E3%83%BC%E3%83%AB%E3%82%B9%E3%82%A4%E3%83%BC%E3%83%88%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%AE%8C%E5%85%A8%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82MCUXpresso%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81Arm%E3%82%84IAR%E3%81%AA%E3%81%A9%E3%81%AE%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%83%84%E3%83%BC%E3%83%AB%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81LPCXpresso55S69%E3%81%AF%E3%80%81SEGGER%E3%82%84P%26amp%3BE%20Micro%E3%81%8B%E3%82%89%E5%85%A5%E6%89%8B%E5%8F%AF%E8%83%BD%E3%81%AA%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%A8%E3%82%82%E4%BD%B5%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId-1060694258%22%20id%3D%22toc-hId-1984247191%22%3E2.%20OM-SE050ARD%E3%83%87%E3%83%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%A6%82%E8%A6%81%3A%3C%2FH1%3E%0A%3CDIV%20class%3D%22%22%3E%0A%3CDIV%20class%3D%22%22%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3EOM-SE050ARD%E3%81%AF%E3%80%81EdgeLock%20SE050%E3%83%97%E3%83%A9%E3%82%B0%26amp%3B%E3%83%88%E3%83%A9%E3%82%B9%E3%83%88%E8%A3%BD%E5%93%81%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%E7%94%A8%E3%81%AE%E6%9F%94%E8%BB%9F%E3%81%A7%E4%BD%BF%E3%81%84%E3%82%84%E3%81%99%E3%81%84%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E5%A4%9A%E3%81%8F%E3%81%AE%20i.MX%E3%80%81LPC%E3%80%81Kinetis%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AA%E3%81%A9%E3%80%81Arduino%E4%BA%92%E6%8F%9B%E3%83%98%E3%83%83%E3%83%80%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E4%BB%BB%E6%84%8F%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8BArduino%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E7%9B%B4%E6%8E%A5I%3CSUP%3E2%3C%2FSUP%3EC%E6%8E%A5%E7%B6%9A%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%AD%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81SE050%E8%A3%BD%E5%93%81%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E8%A9%95%E4%BE%A1%E3%81%A7%E3%81%8D%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%81%AAIoT%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E9%96%8B%E7%99%BA%E3%81%8C%E7%B0%A1%E7%B4%A0%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwww.nxp.com%252Fdocs%252Fen%252Fapplication-note%252FAN12395-OM-SE050ARD_hardware_overview.pdf%22%20target%3D%22_blank%22%3EAN12395%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20879px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F91447i60736281DF2A4AA9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CH2%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%20id%3D%22toc-hId-1751255732%22%20id%3D%22toc-hId--1620158631%22%3E2.1%20OM-SE050ARD%E3%81%A8LPC55S69%20EVK%E3%81%AE%E6%8E%A5%E7%B6%9A%3C%2FH2%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22background%3A%20white%3B%20border%3A%20none%3B%20width%3A%20661px%3B%22%3E%0A%3CTHEAD%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%20143px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%3CSTRONG%3EOM-SE050ARD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%206pt%3B%20width%3A%20203px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%3CSTRONG%3ELPC55S69(%E3%82%B3%E3%83%8D%E3%83%81%E3%82%AB%E3%83%83%E3%83%88%E5%B7%9E%E3%80%82%23-%20%E3%83%94%E3%83%B3%20%23)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%206pt%3B%20width%3A%2084px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%206pt%3B%20width%3A%20164px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%E9%96%A2%E6%95%B0%E5%90%8D%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20padding%3A%206pt%3B%20width%3A%20143px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ESE_SDA(J22-1)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%20203px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EP24-6%E3%82%82P17-3%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%2084px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO1_21%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%20164px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EFC4_I2C_SDA_ARD%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20padding%3A%206pt%3B%20width%3A%20143px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ESE_SCL(J22-4)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%20203px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EP24-5%20%E3%82%82%20P17-1%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%2084px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO1_20%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%20164px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EFC4_I2C_SCL_ARD%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20padding%3A%206pt%3B%20width%3A%20143px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%2B5V_PC%20(J22-2)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%20203px%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%2084px%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%20164px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EVDD_TARGET%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20padding%3A%206pt%3B%20width%3A%20143px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EGND(J22-3)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%20203px%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%2084px%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%206pt%3B%20width%3A%20164px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EGND%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20876px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F93400i1935DCA31214CA82%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId--56198731%22%20id%3D%22toc-hId-867354202%22%3E2.2%20OM-SE050ARD%E3%82%92LPC55S69%20EVK%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E8%A8%AD%E5%AE%9A%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3ESE050%E3%82%92LPC55S%20Arduino%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AB%E3%83%96%E3%83%AB%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BCJ14%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20466px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F93357iCAEA0AEF0D198A29%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8ASE_VDD%203V3%E3%81%AB%E7%9B%B4%E6%8E%A5%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E4%BF%A1%E5%8F%B7%E3%82%92%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81LPC55S%E3%81%AE%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E3%83%94%E3%83%B3%E3%81%8CSilex-2401%20SPI%E3%83%94%E3%83%B3%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81SE_EN%E4%BF%A1%E5%8F%B7%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6SE_VDD%E3%82%92%E9%A7%86%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId--66701835%22%20id%3D%22toc-hId-856851098%22%3E%3CSTRONG%3E3.%20%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AFLPC55S69%20EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E9%80%A3%E6%90%BA%E3%81%99%E3%82%8BNFC%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%A6%82%E8%A6%81%3A%3C%2FSTRONG%3E%3C%2FH1%3E%0A%3CH2%20id%3D%22toc-hId-623859639%22%20id%3D%22toc-hId-1547412572%22%3E%26nbsp%3B%3C%2FH2%3E%0A%3CH2%20id%3D%22toc-hId--1183594824%22%20id%3D%22toc-hId--260041891%22%3E%3CSTRONG%3E3.1%20BLE-NFC-V2%3C%2FSTRONG%3E%3A%3C%2FH2%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fidentification-security%2Frfid%2Fnfc-hf%2Fnfc-readers%2Fclrc663-iplus-i-and-qn902x-nfc-bluetooth-low-energy-solution-for-cohttps%3A%2Fwww.nxp.com%2Fproducts%2Fidentification-security%2Frfid%2Fnfc-hf%2Fnfc-readers%2Fclrc663-iplus-i-and-qn902x-nfc-bluetooth-low-energy-solution-for-consumer-applications%3ABLE-NFCnsumer-applications%3ABLE-NFC%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EBLE-NFC-V2%3C%2FA%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81CLEV6630B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%AF%94%E3%81%B9%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%AE%E3%81%82%E3%82%8B%E5%A4%89%E6%9B%B4%E3%81%8C%E5%B0%91%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%82%88%E3%82%8A%E7%B0%A1%E5%8D%98%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AE%E5%9B%B3%E3%81%AF%E3%80%812%20%E3%81%A4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E9%96%93%E3%81%AE%E3%83%94%E3%83%B3%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82CLRC663%E3%83%97%E3%83%A9%E3%82%B9%E4%BF%A1%E5%8F%B7IRQ%E3%81%AB%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E6%8A%B5%E6%8A%97(4k7%E3%81%8B%E3%82%89VCC)%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F81015iDC208F32BC75463D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId-1303918009%22%20id%3D%22toc-hId--2067496354%22%3E%3CSTRONG%3E3.2%20CLEV6630B%E3%83%9C%E3%83%BC%E3%83%89%3A%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FH2%3E%0A%3CP%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fidentification-security%2Frfid%2Fnfc-hf%2Fnfc-readers%2Fclrc663-iplus-i-nfc-frontend-development-kit-for-access-management-applications%3AOM26630FDK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ECLEV6630B%E3%83%9C%E3%83%BC%E3%83%89%3C%2FA%3E%E3%81%AF%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7SPI%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6LPC1769%20%CE%BCC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9FCLRC663%3CEM%3E%E3%83%97%E3%83%A9%E3%82%B9%3C%2FEM%3E(NFC%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89)%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81LPC1769%20MCU%E3%82%92%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%81%97%E3%81%A6%E5%A4%96%E9%83%A8MCU(%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AFLPC55S69)%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E4%BD%9C%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%0A%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8B%E3%82%896%E3%81%A4%E3%81%AE%E6%8A%B5%E6%8A%97%E3%82%92%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E3%80%81%E5%9B%B3%201%20%E3%81%A7%E8%B5%A4%E3%81%A7%E5%BC%B7%E8%AA%BF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%20style%3D%22width%3A%20730px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F81014i76B6D862DA319FC8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_14.png%22%20alt%3D%22pastedImage_14.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_14.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E7%AB%AF%E3%81%AE%E5%B7%A6%E5%81%B4%E3%81%AB%E3%81%82%E3%82%8BSPI%E3%83%94%E3%83%B3%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E5%A4%96%E9%83%A8MCU(%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AFLPC55S69)%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%0A%3CLI%3E%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E7%B7%9A%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%AC%A1%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AB%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91CLEV6630B%E3%80%82%0A%3CUL%3E%0A%3CLI%3EGND%E3%81%AE%3C%2FLI%3E%0A%3CLI%3EIRQ%3C%2FLI%3E%0A%3CLI%3ECLRC_NRST%3C%2FLI%3E%0A%3CLI%3ESSEL%3C%2FLI%3E%0A%3CLI%3EMOSI%3C%2FLI%3E%0A%3CLI%3EMISO%3C%2FLI%3E%0A%3CLI%3ESCK%3C%2FLI%3E%0A%3CLI%3EIF0%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FLI%3E%0A%3CLI%3EIF1%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3ECLEV6630B%E3%81%AF%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E5%A4%89%E6%9B%B4%E3%81%8C%E5%8A%A0%E3%81%88%E3%82%89%E3%82%8C%E3%81%9F%E5%BE%8C(%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%AE%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%97%E3%81%A8%E3%83%AF%E3%82%A4%E3%83%A4%E3%81%AE%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91)%E3%82%92%E5%9B%B32%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%20style%3D%22width%3A%20580px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F81011iF318A71EE244C1A2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.png%22%20alt%3D%22pastedImage_16.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_16.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB2%E3%81%A4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CTABLE%20style%3D%22background%3A%20white%3B%20border%3A%20none%3B%22%20width%3D%22631%22%3E%0A%3CTHEAD%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%E4%BF%A1%E5%8F%B7%E6%A9%9F%E8%83%BD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22245%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%3CSTRONG%3ELPC55S69(%E3%82%B3%E3%83%8D%E3%83%81%E3%82%AB%E3%83%83%E3%83%88%E5%B7%9E%E3%80%82%23%20-%20%E3%83%94%E3%83%B3%20%23)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22131%22%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%3CSTRONG%3ECLEV6630B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EMOSI%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22245%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EP17-10%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO0_20%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22131%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EMOSI%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EMISO%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22245%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EP17-12%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO0_19%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22131%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EMISO%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ESPI%E3%81%AESCK%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22245%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EP17-14%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO0_21%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22131%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ESCK%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ESPI%20CSEL%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22245%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EP17-6%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO1_11%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22131%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ESSEL%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ERESET%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22245%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EP18-11%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO0_15%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22131%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ECLRCL_NRST%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EIRQ%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22245%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EP18-3%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO1_10%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22131%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EIRQ%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EGND%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22245%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EP17-7%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22105%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20width%3D%22131%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%206.0pt%206.0pt%206.0pt%206.0pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EGND%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20687px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F93356i30E9DFDEBF588B4C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E4%BB%95%E4%B8%8A%E3%81%92%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%AB%E3%80%81MIFARE%20DESFire%20EV2%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AB%E8%BF%91%E3%81%A5%E3%81%91%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%8C%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E5%88%B6%E5%BE%A1%E3%80%8D%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E7%B5%90%E6%9E%9C%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%811%E3%81%A4%E3%81%AELCD%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ELPC55S69%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8LCD%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E9%96%93%E3%81%AE%E6%8E%A5%E7%B6%9A%3A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22margin-left%3A%207.2pt%3B%20margin-right%3A%207.2pt%3B%22%20width%3D%22378%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22144%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.5pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%235B9BD5%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%3CSTRONG%3ETFT%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22123%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.5pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%235B9BD5%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%3CSTRONG%3ELPC55S69%20(%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%20%23%20-%20%E3%83%94%E3%83%B3%20%23)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22112%22%20style%3D%22border%3A%20none%3B%20border-bottom%3A%20solid%20white%201.5pt%3B%20background%3A%20%235B9BD5%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%3CSTRONG%3E%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22144%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23BDD7EE%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ESPI_CLK%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22123%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23BDD7EE%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ED13%3C%2FSPAN%3E%20%3CSPAN%3E(P17-9)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22112%22%20style%3D%22border%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20background%3A%20%23BDD7EE%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO1_2%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22144%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20SPI_MISO%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22123%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ED12%3C%2FSPAN%3E%20%3CSPAN%3E(P17-11)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22112%22%20style%3D%22border%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO1_3%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22144%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23BDD7EE%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20SPI_MOSI%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22123%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23BDD7EE%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ED11%3C%2FSPAN%3E%20%3CSPAN%3E(P17-13)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22112%22%20style%3D%22border%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20background%3A%20%23BDD7EE%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO0_26%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22144%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ESPI_CS_TFT%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22123%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ED10%3C%2FSPAN%3E%20%3CSPAN%3E(P17-15)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22112%22%20style%3D%22border%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO1_1%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22144%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23BDD7EE%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EGPIO_LCD_BL%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22123%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23BDD7EE%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ED9%3C%2FSPAN%3E%20%3CSPAN%3E(P17-17)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22112%22%20style%3D%22border%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20background%3A%20%23BDD7EE%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO1_5%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22144%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EGPIO_LCD_DC%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22123%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3ED7%3C%2FSPAN%3E%20%3CSPAN%3E(P18-1)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22112%22%20style%3D%22border%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EPIO1_9%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22144%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E5V%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22123%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E5V%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22112%22%20style%3D%22border%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22144%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EGND%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22123%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%3EGND%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22112%22%20style%3D%22border%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20background%3A%20%23DDEBF7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.waveshare.com%2Fproduct%2Fmodules%2Foleds-lcds%2Farduino-lcd%2F2.8inch-tft-touch-shield.htm%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EWaveshare%E3%81%8B%E3%82%892.8%E3%82%A4%E3%83%B3%E3%83%81TFT%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FA%3E%E3%82%92%E6%B3%A8%E6%96%87%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%93%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3AP%20%2F%20N%3A2.8%E3%82%A4%E3%83%B3%E3%83%81TFT%E3%82%BF%E3%83%83%E3%83%81%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%83%96%E3%83%A9%E3%83%B3%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20337px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F82819iCBF2CC4F1EEBD8C1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH1%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2024px%3B%22%20id%3D%22toc-hId-1293414905%22%20id%3D%22toc-hId--2077999458%22%3E%3CSPAN%3E4.%20LPC55S69%E3%81%A7%E3%80%8CSecure%20Access%20to%20Industrial%20IOT%E3%83%87%E3%83%A2%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3A%3C%2FSPAN%3E%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3COL%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3ELPC55S69-EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%88%9D%E3%82%81%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2FGet-Started-with-the-LPC55S69-EVK%3AGS-LPC55S69-EVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELPC55S69-EVK%20%7CNXP%E3%81%AE%3C%2FA%3E%20%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AALPC55S69-EVKboard%E3%81%AESDK%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E5%BF%85%E3%81%9A%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%E3%80%8Cdemobinaries.zip%E3%80%8D%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%80%82%E3%81%93%E3%81%AEzip%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE2%E3%81%A4%E3%81%AEbin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%0A%3COL%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3Eex_prepareCard.bin%20-%20%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E9%81%A9%E5%88%87%E3%81%AA%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8AES%E3%82%AD%E3%83%BC%E3%82%92%E5%82%99%E3%81%88%E3%81%9FMIFARE%20DESFire%20EV2%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E6%BA%96%E5%82%99%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92LPC55S69%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92LPC55S69%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81MCUxpresso%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AE%E4%B8%8A%E3%81%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E7%BD%AE%E3%81%8D%E3%80%81%E3%80%8CRESET%20KEY%E3%80%8D%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6MCU%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3Eex_prepareSe050.bin%20-%20%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E9%81%A9%E5%88%87%E3%81%AAAES%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84SE050%E3%82%92%E6%BA%96%E5%82%99%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92LPC55S69%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MCUxpresso%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82LPC55S69%20arduino%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AB%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%81%AEOM-SE050ARD%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%ADUSB%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92MCU%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%80%8CRESET%20KEY%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6MCU%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%E6%89%8B%E9%A0%862.1%E3%81%A82.2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%811%E3%81%A4%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A8%E3%83%AC%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A81%E3%81%A4%E3%81%AEMIFARE%20DESFire%20EV2%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E6%BA%96%E5%82%99%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%80%81MCUxpresso%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%AC%A1%E3%81%AE%E3%83%93%E3%83%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92LPC55S69%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CBR%20%2F%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%85%A8%E4%BD%93%E3%82%92MCUxpresso%E7%92%B0%E5%A2%83%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%0A%3COL%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AB%E3%81%82%E3%82%8BEmbeddedWorld2019DemoLatest.zip%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E3%81%93%E3%81%AEzip%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92MCUxpresso%E7%92%B0%E5%A2%83%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%20MCUXpresso%20IDE%20%E3%81%AB%20(%E3%83%89%E3%83%A9%E3%83%83%E3%82%B0%20%E3%82%A2%E3%83%B3%E3%83%89%20%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%81%A7)%20%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%20%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%20%E3%83%91%E3%83%8D%E3%83%AB%E3%81%8B%E3%82%89%20%5B%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%5D%20%E3%82%A2%E3%82%A4%E3%82%B3%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%9F%E3%82%89%E3%80%81%E5%AE%9F%E8%A1%8C%E3%82%A2%E3%82%A4%E3%82%B3%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%82%8B%E7%94%BB%E5%83%8F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%82%8BMCUXPRESSO%E3%81%AE%E7%94%BB%E5%83%8F%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E4%BB%8A%E3%81%99%E3%81%90%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81Reader%20%E3%81%AE%E4%B8%8A%E9%83%A8%E3%81%AB%E3%81%82%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E5%AD%98%E5%9C%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E9%96%89%E3%83%AB%E3%83%BC%E3%83%97%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82LCD%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%99%E3%81%A8%E3%80%81%E3%80%8CSecure%20Access%20to%20Industrial%20IOT%20demo%202019%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%82%8B%E7%94%BB%E5%83%8F%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%80%8C%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81NFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%85%A5%E3%82%8A%E3%80%81%E8%AA%8D%E8%A8%BC%E3%81%99%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E6%8E%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E5%BD%BC%E3%81%AF%E3%81%99%E3%81%90%E3%81%AB%E3%80%8C%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%8C%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E8%B5%A4%E3%81%84%E3%82%A2%E3%83%A9%E3%83%BC%E3%83%88%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3ENFC%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%81%AE%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AB%E8%BF%91%E3%81%A5%E3%81%91%E3%82%8B%E3%81%A8(%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88)%E3%80%81LCD%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E3%80%8C%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%8C%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E8%B5%A4%E3%81%84%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%82%8B%E7%94%BB%E5%83%8F%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E3%80%8C%E6%BA%96%E5%82%99%E3%81%95%E3%82%8C%E3%81%9FDESFireEV2%E3%80%8D%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E4%B8%8A%E3%81%AB%E7%BD%AE%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E3%80%81%E4%B8%8B%E3%81%AE%E5%86%99%E7%9C%9F%E3%81%A7%E3%81%AF%E3%80%81%E7%B7%91%E8%89%B2%E3%81%AE%E3%80%8C%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%8C%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%3E%E5%86%99%E7%9C%9F%E3%81%AF%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId--766303897%22%20id%3D%22toc-hId-157249036%22%3E%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3A%3C%2FH1%3E%0A%3COL%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3ENFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%20i.MX%20RT1050%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82(%E3%83%9D%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E)%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-341843%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-341843%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3ELPC55S69%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-based-processors-and-mcus%2Flpc-cortex-m-mcus%2Flpc5500-cortex-m33%2Flpcxpresso55s69-development-board%3ALPC55S69-EVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-based-processors-and-mcus%2Flpc-cortex-m-mcus%2Flpc5500-cortex-m33%2Flpcxpresso55s69-development-board%3ALPC55S69-EVK%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3EBLE-NFC-V2%E3%81%AE%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fidentification-security%2Frfid%2Fnfc-hf%2Fnfc-readers%2Fclrc663-iplus-i-and-qn902x-nfc-bluetooth-low-energy-solution-for-consumer-applications%3ABLE-NFC%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fidentification-security%2Frfid%2Fnfc-hf%2Fnfc-readers%2Fclrc663-iplus-i-and-qn902x-nfc-bluetooth-low-energy-solution-for-consumer-applications%3ABLE-NFC%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fpart%2FCLEV6630B%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpart%2FCLEV6630B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ECLEV6630B%E8%A3%BD%E5%93%81%E6%83%85%E5%A0%B1%7CNXP%E3%81%AE%3C%2FA%3E%26nbsp%3B%3C%2FLI%3E%0A%3CLI%20style%3D%22margin-left%3A%20.25in%3B%22%3ESE050%3A%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2FSE050%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ewww.nxp.com%2FSE050%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FOL%3E
評価なし
バージョン履歴
最終更新日:
‎10-12-2023 03:37 AM
更新者:
