Patch to enable SSI_ASRC_P2P capture function for SebreSD board
Modified based on https://community.freescale.com/docs/DOC-95342#comment-9739
You can use 'arecord -Dhw:0,1 -c 2 -f S16_LE -r 44100 | aplay' to test this patch.
Currently only supports 16bit output width, for 24bit, the voice of the captured data will be much bigger in one channel than the other for this patch.
No ratings
Version history
Last update:
‎04-16-2014 11:07 PM
Updated by:
