I have a new to using MQX version 3.7 and CW 10.1, I have a working project using a mcf51jm and I have not found documentation on how MQX handles unused interrupts. In smaller project, with out a RTOS I either wrote a handler that rerecorded an exception in a error log or forced a watchdog.
Any suggestion on how to handle, assuming MQX does not handle unused interrupts?
Solved! Go to Solution.
By default MQX will block the task that was running when an unused interrupt occurs. If you want to display details of the interrupt call _int_install_unexpected_isr(); right at the beginning of your application this will display the vector of the unused interrupt on the console.
