Can anyone point me to some example code using Flexbus? I need to connect to an FPGA & RAM via this bus. Thanks!
Solved! Go to Solution.
Hello Intevac_coder,
Please reference the below thread:
https://community.freescale.com/message/92366#92366
Hope this helps.
David
Hope this helps.
David
David,
Thank you - I will check into it!
Aaron
