I am able to create file on the SD card usign MFS... and I am able to connect to a FTP server using RTCS.... but if I want to send a file to an FTP server using RTCS... how I get access to my files?
I tried:
FTP_command_data(handle, "STOR a:test.txt\r\n", stdout, stdout, FTPMODE_PORT | FTPDIR_RECV);
before using this I mounted my SD as a: like in the tower demo...
and the test.txt file exists on the SD card...
Maybe I missed an information in the doc...
Thank you
Solved! Go to Solution.
Sorry I was wrong all the way...
For the ones that are interested...
fd is a file pointer opened in read for the file you want to transfer...
And don't forget to put the right direction... FTPDIR_SEND ...
response = FTP_command_data(handle, "STOR test.txt\r\n", stdout, fd, FTPMODE_PORT | FTPDIR_SEND);
As always! RTFM!
As always! RTFM!
