In poll mode t takes 2.2us to send one character in 12MHz baudrate.
In interrupt mode t takes 4.0us to send one character in 12MHz baudrate.
I checked the poll mode driver, it calls _dspi_polled_tx_rx() for every character it sends, and it also wait for the read back in this function.
The driver doesn't take the advantage of FIFO
Solved! Go to Solution.
Hi Mircofelix,
Our MQX development team is working to improve the driver performance and an update is expected in our MQX3.8 release mid next month.
David
I have the same problem.
It 'been resolved?
maurizio
Have you tried the processor expert driver code?
I first tried I2C with MQX driver, it jammed. Then changed to P&E code (for K60/K10), works fine.
The driver functions are in one (generated) file, easy to check what's happening.
~Mark
Hi Mircofelix,
David
