Hello All,
Does anyone have any example code, that use the DMA to get data from an input capture timer channel using
the Kinetis?
Did you (original posting person) ever find the code? I see you have been on the hunt since April 14th 2011.
This is exactly what I'm trying to do as well.... ever find any examples?
I am in the exact same boat. I checked all code examples from IAR tool suite which I have installed none of which could be found. If you find or know the where about, please keep me in the loop. I am wondering if CodeWarrior tool suite has an example of input capture with DMA.
