Hello everyone,
I have a problem or a question...
my application is written in C and when debugging, it is possible to see CPU registers? I mean see what is stored there.
when you programm using assember, debugging always open memory window, and all registers are seen.
possible to do that with C debugging?
Solved! Go to Solution.
Hello
This depends on which version of CodeWarrior you are using.
If you are using V6.3, you can open the component MCURegisters to look at content of the registers.
Inside of the debugger select Component > Open and select Mcuregisters.
If you are using V10.x, you should be able to see register value in the Register View.
CrasyCat
Hello
CrasyCat
