i want to use Eclipse with the HCS12DP128 an a P&E Multi BDM? Have someone do that?
I have downloaded eclipse on http://gcc-hcs12.com- but the connection here is via com port.
Thank you
Markus
A friend of mine wrote a Linux driver for the P&E USB BDM, but it is incomplete.
No idea if that is even remotely helpful.
James
