I use MC9S08SH32, in the Data Sheet Chapter 9 ADC converter It is possible to use a Temperature sensor, but I do not understand what number pin use it ?
What type sensor it, PTC, thermocouple,...
The channel Assignment is AD26.
Thank you
Solved! Go to Solution.
AD26 is for the internal temperature sensor. It is not available on an external pin.
